MeOmYo
2001 Golf, 226k, vibration is mostly in 4th & 5th, under load at ~2500-3000 rpms.
I've had this vibration in the front end for a month or so and last week I thought I'd try to remedy the problem by replacing, what I thought was a bad drivers side CV shaft assembly. Turns out, that did nothing to help so I removed the passenger side axle and replaced the inner CV joint with the CV joint off the driver's side I had removed. Vibration is still there. I've checked the motor mounts and bolts and they are all fine/tight. Tires, ball joints, wheel bearings etc are all good so I think I'm good from wheels to tranny. I'm not really sure what to look for on the dogbone as I've read these can cause this as well.
Any suggestions?
Any suggestions?
