amstel78
- Joined
- Jan 24, 2012
- Location
- Shohola, PA
- TDI
- 2012 Golf TDI [buyback completed 14/1/2017] 2006 S65 AMG
Car after 72000 miles started developing a front end clunk. Can't seem to replicate it all the time. I do hear it at slow speed when traversing uneven pavement, or turning over uneven ground. First thought it was ball joint but all seems tight. I haven't had time to check the subframe or sway bar bolts.
Does anyone know what factory torque specs are for the sway bar bolts? I know subframe is TTY so if it's those, I'll have to purchase an aftermarket bolt and collar kit.
Also, a search on the net keeps coming up with some sort of VAG TSB with the following number 2014645, but I can't seem to find an actual TSB for front suspension noise.
