Sleet
Ok here's the deal. I have a sporadic clunking noise from the drivers side front end. '98 jetta 315k miles.
I heard it last night on the freeway. I had pulled off on an exit ramp and got out and checked tires (had recently gotten some new ones installed and figured I'd double check that the tire shop had tightened them) Everything was fine and I got back on the freeway and after a mile or so the noise was back again (it just suddenly started it didn't start up gradually)
I pulled over and again checked the tires and drove the last 3-4 mile home and there wasn't a sound.
So today I get up and head out. I drive about 1/2 mile on side streets until the freeway and I pull out and go for about 4 miles. As I'm slowing down off the exit I heard the noise again. as I'm coasting it intensifies and by the time I'm stopping at the light I'm hearing clunk, clunk, clunk.
I pull off and slowly make my way to a gas station and get out and it's dark and can't see a darn thing. I try to feel the cv joints on the drivers side and can't make out much. So I get back in the car call into work and decide to wait it out until it gets light.
I get out an hour later and try to take a look at things and nothing seems out of the norm. So I try to slowly drive it back (on side streets) and it's making the clunk noise constantly and consistently. The noise is directly associated with how fast the tires are spinning.
While driving I also notice that the clunking almost goes away if I'm just giving it enough fuel to keep the speed steady / or just slight increasing the speed. If I try to coast it gets really louder and more pronounced.
I come up to a Target and since it's still early and no one's there I pull into the parking lot and decide I better get this thing towed before I break something. So as I'm pulling in and slowing down it's still making the clunk... clunk.. clunk (I can feel it even in the peddles) so I'm thinking great! BTW the clunking isn't associated with the road surface at all. So as I slow down to a stop. get out and look under again. I decide to move it forward 10 feel to avoid lying in a puddle and suddenly there wasn't a clunking sound?!?!?!
So then I drive a little further and a little further and nothing! It's acting completely normal! I've since driven home, and taken it on a few short trips around on the freeway I've been trying to get it to make the noise. Driving it rather hard, sharp corners (some turning the steering way all the way both directions) flooring it on the freeway etc.
The sound is completely gone and I'm a bit clueless. I know I have a front bearing that has started to make a little noise so I figured I'd try to get that changed later today but wasn't sure if I need to grab a drive shaft or something?
the only things I could think of are either drive shaft or transmission.
Anywone have any ideas?
