Front caliper top sliding pin stuck
bmwM5power
Rochester NY
15 GSW TDI S 6MT 02 JETTA TDI GLS 5MT 15 GOLF TDI SE 6MT 15 GOLF TDI SEL DSG
Not sure if I was suppose to lubricate the front caliper sliding pins on 2015 GSW, ive seen both suggestions on the internet, but i did it anyway, put some ATE grease from FCP, now the top pin with the rubber sleeve/ bushing is getting stuck, the sleeve has gotten swollen i suppose, it doesnt look swollen but its hard to put it in or out. The question is how important is that rubber sleeve on the top sliding pin? can i remove it and now lubricate pins normally? I obviously cant go back in time and undo what i did
Nuje
Island near Vancouver
You mean this rubber boot?
I'd say that's very important. On one car that came to me (Audi A4), there was just a slight tear in it, and the sliding pin was corroded solid in there.
Those boots are pretty cheap - I had a few that came as part of a brake pad set, so was able to replace on the spot (after the hour or so of working that pin free and then cleaning it up).
Only grease I've ever used in there is silicone grease (friendly to rubber).
bmwM5power
Rochester NY
no, not the boot, one of the pins ( the top one) has a rubber sleeve or bushing
pedroYUL
MI, USA
2015 Passat CVCA; 2015 GSW CRUA; 2004 wagon BEW(brother)
Never seen that sleeve. Did you buy your car new?
pedroYUL
MI, USA
hmmm, I don't recall that sleeve in my mk7, but it's been long since I had those brakes apart.
740GLE
NH
that sleeve is prob internal to the caliper bracket and should stay put when you pull the pin and there to take up some slop so i'd want to get another one installed.
Can't say i've seen those sleeves on a PN list, not sure if you need a new caliper bracket.
bmwM5power
Rochester NY
its not internal to caliper, there is a special place on the sliding pin for the rubber sleeve, a groove/ recess or whatever you want to call it, when you google "MK7 front caliper slide pins" you can see this.
RIP TDI
Santa Barbara, CA
2015 GSW SE 6MT 2001 Golf GLS 5MT 1996 Passat Wagon
Well you have the answer to your original post: get that kit and use that grease.
bmwM5power
Rochester NY
or replace with the normal pin, the question was about the importance of the sleeve, TRW SJ1376 kits unfortunately are not sold in US, and the ones from rockauto dont come with the sleeves
paperthin
Toronto
15 A3 TDI
If this helps. On my wife's lexus, I experienced the same thing, one of the pins has that rubber bushing. I took it off and tossed it because it did swell. I had no problem after that. For just over two years no problems, then we sold the vehicle so I don't know what happened after that.
740GLE
NH
Ah must have confused it with the rear carriers, i didn't see any rubber on the rear pin.
So how does that rubber sleve compare to the 312 caliper carriers? I wonder if only TRW carriers have them and others dont?
