GTSLOW
So I'm going through the brakes on all four corners. I'm using kits from the fine folks at ID Parts. Unfortunately my passenger side caliper bracket has a stripped hole where the caliper pin goes in. I'm assuming the previous owner waaaaay overtightened it. Does anyone know what the thread is for the two pins? I'd like to helicoil the stripped hole considering a new caliper bracket is $140.
Also one of the front pads from ID Parts has a sensor and harness. What year Passats utilized this?
Thank you.
Thank you.
