Front and Rear Differential fluid
alxjhn
Philadelphia
Q7
What kind of front and rear differential oil does 2011 Audi Q7 TDI 3.0???? Transfer case????Also has 8 speed transmission.
bryanmabbott
Phoenix
'02 VW Golf Manual; '13 Touareg TDI
Front and rear diff take 75w90; 0.8qt for the front, 1.1qt for the rear.
Transfer case take a specific fluid part number G 052 536 A2, 0.7qt.
Transmission fluid part number is G 055 540 A2, 6.3qt refill spec but IIRC when I did mine on my Touareg (same transmission) that spec is to account for overfill and you have to set the fluid level correctly by getting the trans up to temp via VCDS or IR temp gun and loosen the drain bolt with the engine on until all the excess fluid drains. I used Ravenol ATF-WS but you can easily use Toyota WS transmission fluid as it's easier to find and reasonably priced.
A1sailor
Ontario, Canada
2015 Q5 TDI 3.0
I used the Ravenol 75W- 140 GL5 for my 2015 Q5 transfer case, apparently VW ok'd and less cost that the OEM brand.
nayr
Colorado
2014 Audi Q7
G052536A2 (Gear Oil) is OEM fluid for the transfer case
G052145S2 is OEM fluid for Diffs.
Ravenol TLS-LV is good alternative to OEM ATF, fraction of the cost.. it actually holds ~11qt but you can only get ~6qt out the drain, so do a couple changes 100 miles of eachother if you want to do a more complete change.. you end up using alot of ATF but your not paying OEM prices so its not that bad.
alxjhn
Philadelphia
Q7
Transfer case fluid
Can I use this fluid in the transfer case
Idemitsu 30040096-95300C020 ATF Type TLS-LV (WS)
nayr
Colorado
2014 Audi Q7
No, thats your transmission fluid.. transfer case is G052536A2.. there is no aftermarket equivalent afik.. you only need like one bottle, suck it up.. minus engine, you need 3 different types of oil to do a full drivetrain lube job.. Diff, Transfer Case, Transmission are all different.
alxjhn
Philadelphia
Q7
Transfer case fluid
So it only takes 1 bottle for the transfer case????G052536A2 (Gear Oil) is OEM fluid for the transfer case... i already did the transmission filter and fluid change. Used febi atf and filter kit from ecstuning. I used redline 75w 90 in the front and rear differential.
nayr
Colorado
2014 Audi Q7
~0.7L capacity of gear oil for transfer case, G052536A2 is 1L..
0.7 < 1
so it only takes 1 bottle of G052536A2 for the transfer case.. the very first reply to you contained all this information.
