That wasn't checked....heres what I get now:
KW1281Test 0.55-beta (
https://github.com/gmenounos/kw1281test/releases)
Args: COM2 9600 17 DumpEeprom 204 6
Opening serial port COM2
Unhandled exception: System.IO.FileNotFoundException: Could not find file 'COM2'.
File name: 'COM2'
at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
at System.IO.Ports.SerialPort.Open()
at BitFab.KW1281Test.Interface.GenericInterface..ctor(String portName, Int32 baudRate) in C:\Users\gmeno\src\kw1281test\Interface\GenericInterface.cs:line 23
at BitFab.KW1281Test.Program.OpenPort(String portName, Int32 baudRate) in C:\Users\gmeno\src\kw1281test\Program.cs:line 325
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 153
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 28
Args: COM5 10400 17 DumpEeprom 204 6
Opening serial port COM5
Unhandled exception: System.IO.FileNotFoundException: Could not find file 'COM5'.
File name: 'COM5'
Args: COM5 9600 17 DumpEeprom 204 6
File name: 'COM5'
File name: 'COM5'
