70chips
- Joined
- Feb 16, 2021
- Location
- UK
- TDI
- 2001 C5 Allroad 2.5TD. 2008 C6 Allroad 3.0TDI. Cheeky tt Roadster 2001
Well, I downloaded the beta V0.50and got the TT round.
Connected up and used the DumpMarelliMem 14336 2048 command and no joy, just the same. tried disconnecting for a while and re attempted but the same result.
I've copied the results incase I'm not doing something right!
On a technical note, what actually is the difference between the D14 and D09? Is it the type of chip or a different manufacturer?
Never ceases to amaze me how many variable there are in electronics on cars, even with identical part numbers with identical sub letters too!!
KW1281Test 0.50-beta (https://github.com/gmenounos/kw1281test/releases)
Args: com3 9600 17 DumpMarelliMem 14336 2048
Opening serial port com3
Sending wakeup message
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
ECU: 8N2920980A KOMBI+WEGFAHRS. M73 D09
Software Coding 00444, Workshop Code: 00000
Sending block 0x6C
Writing data to cluster microcontroller
Receiving ACK
Unhandled exception: System.TimeoutException: The operation has timed out.
at System.IO.Ports.SerialStream.ReadByte(Int32 timeout)
at System.IO.Ports.SerialPort.ReadByte()
at BitFab.KW1281Test.Interface.GenericInterface.ReadByte() in C:\Users\gmeno\src\kw1281test\Interface\GenericInterface.cs:line 33
at BitFab.KW1281Test.KwpCommon.ReadByte() in C:\Users\gmeno\src\kw1281test\KwpCommon.cs:line 57
at BitFab.KW1281Test.Program.WriteMarelliBlockAndReadAck(Byte[] data) in C:\Users\gmeno\src\kw1281test\Program.cs:line 727
at BitFab.KW1281Test.Program.DumpMarelliMem(IKW1281Dialog kwp1281, ControllerInfo ecuInfo, UInt16 address, UInt16 count) in C:\Users\gmeno\src\kw1281test\Program.cs:line 488
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 188
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 24
Regards
Alan
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Sending block 0x6C
Receiving ACK
Regards
Alan
