Free VDS-Pro / VagTacho Alternative
2002_auto_tdi
Virginia
03 5spd wagon and 02 01m sedan
Works fine for 56 (Radio). I wonder if VCDS can see 46.
I believe I remember my guru mentioning that he could not see 46 on my 02 Auto TDI using VCDS. I wonder if the way that I am fixing the driver's door switch is doing this...that's the only commonality I can think of. I ran an alarm pin switch to the door light on both. Works fine in every other way.
2002_auto_tdi
Virginia
I recently changed door lock options on 46 via VCDS and they worked fine. Something else is up.
2002_auto_tdi
Virginia
56 not working....I take it back. 56 makes the radio pop but same cryptic error message. I give up for now. Only 17 shows signs of life.
C:\>kw1281test67 COM5 10400 17 ReadEeprom 0 2048
KW1281Test: Yesterday's diagnostics...Today.
Version 0.67-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM5 10400 17 ReadEeprom 0 2048
OSVersion: Microsoft Windows NT 10.0.19042.0
.NET Version: 6.0.0
Culture: en-US
Opening serial port COM5
Sending wakeup message
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
ECU: 1J0920906L KOMBI+WEGFAHRSP VDO V11
Software Coding 06232, Workshop Code: 01120
Sending Custom "Read Software Version" blocks
Sending Custom "Unlock Additional Commands" block
00: VWK501LL $00 $01
01: $75 $18
02: $09 $05 $01 $0A $0F $37
03: VW/Sk LL Serie Maske
Sending Custom "Unlock partial EEPROM read" block
Unlock code for software version VWK501LL 01.00 is 36 3D 3E 47
Sending Custom "Need Seed/Key?" block
Cluster is unlocked for ROM/EEPROM access. Skipping Seed/Key login.
Sending ReadEeprom block (Address: $0000, Count: $01)
Received "Read EEPROM Response" block: 00
Address 0 ($0000): Value 0 ($00)
Sending EndCommunication block
2002_auto_tdi
Virginia
So switched USB port ...now COM 6...USB PORT on right closest to screen (just a personal note)
Must specify 9600 for 46 for it to work:
C:\>kw1281test67 COM6 9600 46 ReadEeprom 0 2048
Args: COM6 9600 46 ReadEeprom 0 2048
.NET Version: 6.0.0
Culture: en-US
Opening serial port COM6
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 1C0959799C 8A Komfortgerat HLO 0003
Software Coding 00258, Workshop Code: 01266
Sending Login block
BUT for 17 to work must specify 10400 WTH?
C:\>kw1281test67 COM6 10400 17 ReadEeprom 0 2048
Args: COM6 10400 17 ReadEeprom 0 2048
.NET Version: 6.0.0
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
01: $75 $18
2002_auto_tdi
Virginia
Closer?
I don't like the Eeprom read failed line at end.
Is this sufficient to start writing you think?
C:\>kw1281test67 COM6 10400 17 ReadEeprom 04352
Args: COM6 10400 17 ReadEeprom 04352
.NET Version: 6.0.0
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
01: $75 $18
Sending ReadEeprom block (Address: $1100, Count: $01)
EEPROM read failed
2002_auto_tdi
Virginia
I think that I was tired. Anyways, much closer. Could someone please point out the "value"?
Is it "45"? If so, what is next?
Of note, I must pull the usb end each time I do a read or I get that cryptic error message.
Also of note, 4352, 4353, 4354 all have the same "value" of 45.
Looks like 45 translates to 101101 binary.
C:\>kw1281test67 COM6 9600 46 ReadEeprom 04352
Args: COM6 9600 46 ReadEeprom 04352
.NET Version: 6.0.0
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Sending Login block
Received "Read EEPROM Response" block: 2D
Address 4352 ($1100): Value 45 ($2D)
2002_auto_tdi
Virginia
I just got here today. Looks like you had a hell of a time. Glad you got it working.
Thanks for this! I am just wondering why the changes on my 03 5 spd Wagon worked on 4352, 4353, and 4354 and I didn't need to touch anything else. I am tempted to mess with the remote windows but I can't think of an example which that would be helpful for...then again, I have noticed a tendency for most people here not to do anything at all for the sake of doing it!
I probably want to run through the whole 9 yards to make sure that nothing is off before calling victory. I see that kennethsime had some trouble and appears to have a wagon like me but went about things at different addresses. It seems like the rear doors have to be unlocked for the hatch to open. Not sure if this is where I want it.
I have to hit the remote unlock button multiple times to get the hatch to open but that is fine with me. I have it programmed to unlock all doors when the key is removed with VCDS.
I think I am in a good spot.
EDIT: Nothing unusual...if the vehicle is in a locked state though and I unlock it with the key fob I have to be FAST to get the hatch open or it relocks (silently) within a few seconds. Not sure if modifying another address value can address this.
Mozambiquer
Versailles Missouri
1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI
The wagons are set up differently, I ran through trouble when I did the hatch on my Passat wagon. Finally got it figured out.
2002_auto_tdi
Virginia
As an additional data point: It just so happens that I had a 2003 Jetta wagon here today; changed 4361,2,3 from 202 to 195, and 4370,1,2 from 6 to 4 - and I have hatch unlock and fob window-open/close working perfectly.
Hi Nuje,
Do you remember the hatch behavior of the 03 Jetta Wagon when modifying just 4370, 1, and 2?
I modified 4352 - 4354 and it does open with the door lock remote now BUT it is a mad rush to grab at the hatch if the vehicle is locked before it silently relocks. I had already set doors to auto unlock with VCDS so the hatch also now stays unlocked while removing the key along with the doors BUT the mad rush starts if unlocking the hatch via the door lock key on the remote. I am considering taking 4352 - 4354 and setting them back to their default and changing only 4370-4372 instead.
Thanks.
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2003; 2016 A3 e-tron
Yes. I did not change anything at 4352,3,4 - my only changes for hatch unlock were at 4370,1,2.
The other change I have done is that I have all doors set to unlock with just ONE press of the unlock button on the key fob (that's a change in coding or adaptations with VCDS).
2002_auto_tdi
Virginia
That is very helpful. Making it so all doors unlock in one swoop is helpful.
Do you by chance remember if the hatch relocks with your changes when unlocked via the fob after the system has been armed?
Thanks.
Nuje
Yes it does. It basically behaves the same as any of the other doors; e.g., if the passenger door is unlocked, the hatch is unlocked (and stays so). If passenger door is locked, same with hatch.
2002_auto_tdi
Virginia
Thanks. So interestingly enough, after disabling selective locking from VCDS as you mentioned, my change at 4361 62 63 works the same way you articulated. I guess maybe either way works.
kennethsime
California
2004 Jetta Wagon GL TDI 5-Speed Baltic Green
Here's my change log so far:
I'm debating going to go back in to enable the single-button unlock of all doors. Easier is better, but also I kind of like the idea of only unlocking my own door. Hmm...
2002_auto_tdi
Virginia
Wow, you are meticulous. I used to be but now make changes at risk. Thanks for laying this out. I will be monitoring how my changes pan out and report back if I notice any glitches.
sebba
Arad, RO
Hello and thank you for your great work.
I tried to run kw1281test.exe v0.71beta in combination with a VAG204 interface (VCDS clone?)
It looks like this:
I tried under W7Pro/x86 and also under W10Pro/x86, where VCDS is working as expected.
Also, I disabled boot in intelligent mode in VCDS, test, save... remove and replug the cable, for booting in dump mode. (not very sure this is the correct procedure to boot dumb mode, also)
After that, when I run kw1281test.exe, doesn't matter if W7 or W10, and doesn't matter what command (GetSKC, DumpEeprom etc) I always have the following errors:
Code:
Version 0.71-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM3 10400 17 GetSKC
OSVersion: Microsoft Windows NT 10.0.19043.0
.NET Version: 6.0.0
Culture: en-US
Opening serial port COM3
Reading sync byte
Retrying wakeup message...
Reading sync byte
Reading sync byte
Caught: System.InvalidOperationException Controller did not wake up.
Unhandled exception: System.InvalidOperationException: Controller did not wake up.
   at BitFab.KW1281Test.KwpCommon.WakeUp(Byte controllerAddress, Boolean evenParity) in C:\Users\gmeno\src\kw1281test\KwpCommon.cs:line 59
   at BitFab.KW1281Test.Program.Kwp1281Wakeup(Boolean evenParityWakeup) in C:\Users\gmeno\src\kw1281test\Program.cs:line 364
   at BitFab.KW1281Test.Program.GetSkc() in C:\Users\gmeno\src\kw1281test\Program.cs:line 749
   at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 296
   at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 30
The VCP driver is installed and the COM port is 3
I tried also to read software versions for ECU or else, i tried with 10400 and also with 9600, W7 and W10, as I said... nothing works.
The car is an Ibiza 1.2 12v 2006
Any advice is welcome.
Thank you,
Seb
gmenounos
Watertown, MA, USA
It sounds like you configured everything right. Unfortunately I don't have that same cable so I'm not sure why it's working with VCDS but not with kw1281test. The only cables I've successfully tested with are:
If you connect to your cluster with VCDS, does it show the protocol as KW1281 like this?
sebba
Arad, RO
Thanks for reply.
Regarding your question, I don't remember...
I'll check soon and reply.
Thank you
sebba
Arad, RO
Hello again,
I just checked and the protocol is KW1281, indeed
The "intelligent mode" is disabled
Also, for Engine, the protocol is KWP2000
Could be a bad clone cable?
LE:
Inside, my cable is exactly like this: http://obd2toolz.com/index.php?route=product/product&search=vag 20.4&product_id=2066
LLE:
I checked the cable with "VAGCOM_HWType.exe" and also with "C-Test.exe". It seems my cable is a "functional fake" one :)
Rjbiga
Kampala, Uganda
Vw Gold MKIV
Hi @gmenounos,
Thanks for your efforts on the code. I downloaded v66 to be able to pull my car's SKS. I am not able to locate the SKC. Any help?
Thanks again!
Version 0.66-beta (https://github.com/gmenounos/kw1281test/releases)
.NET Version: 5.0.8
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 1J0920805E KOMBI+WEGFAHRS. BOO V01
Software Coding 01122, Workshop Code: 00046
Unsupported cluster: 1J0920805E KOMBI+WEGFAHRS. BOO V01
gmenounos
Watertown, MA, USA
It looks like your cluster is made by Bosch/Motometer and it's running a software version that I haven't tested before. Can you try the DumpRB8Eeprom command and see if that works?
.\kw1281test.exe COM3 10400 17 DumpRB8Eeprom 66560 1024
Rjbiga
Kampala, Uganda
Vw Gold MKIV
Have tried as advised. This is what I get
Args: COM3 10400 17 DumpRB8Eeprom 66560 1024
.NET Version: 5.0.8
Culture: en-US
Reading sync byte
Reading sync byte
Reading sync byte
at BitFab.KW1281Test.Program.Kwp2000Wakeup(Boolean evenParityWakeup) in C:\Users\gmeno\src\kw1281test\Program.cs:line 355
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 269
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 25
Rjbiga
Kampala, Uganda
Vw Gold MKIV
Also tried this
PS C:\> .\Ross-Tech\kw1281test_066\kw1281test.exe COM3 9600 1 GetSKC
Args: COM3 9600 1 GetSKC
.NET Version: 5.0.8
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 038906012M 1,9l R4 EDC 0000SG 2813
Software Coding 00002, Workshop Code: 00046
Reading sync byte
Keyword Lsb $6B
Keyword Msb $8F
Protocol is KW 2027 (8N1)
KW Version: 2027
Sent: 82 01 F1 10 89 0D (startDiagnosticSession)
Received: 82 F1 01 50 89 4D (startDiagnosticSession ACK)
Sent: 82 01 F1 10 85 09 (startDiagnosticSession)
Received: 83 F1 01 7F 10 78 7C (startDiagnosticSession NAK reqCorrectlyRcvdRspPending)
Received: 83 F1 01 50 85 2F 79 (startDiagnosticSession ACK)
Sent: 82 01 F1 27 41 DC (securityAccess)
Received: 84 F1 01 67 41 00 00 1E (securityAccess ACK)
Sent: 82 01 F1 27 42 DD (securityAccess)
Received: 83 F1 01 67 42 34 52 (securityAccess ACK)
Sent: 08 34 40 E0 00 00 00 04 40 A0 (requestDownload)
Received: 02 74 FF 75 (requestDownload ACK)
Sent: 00 FF 36 A5 A5 14 E0 00 00 3C E0 00 00 42 E0 00 00 40 E4 00 00 02 47 13 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 00 08 00 09 00 0A 00 0B 00 0C 00 0D 00 0E 00 0F 80 0F A0 0F C0 0F 00 10 45 2F 7D 64 9B C3 BE 88 4F D8 E6 F0 FE E7 BB 6A 48 61 2D 50 48 62 2D 1F E6 F1 00 E6 F4 41 01 00 47 F4 23 00 2D 1A 47 F4 36 00 2D 1A 47 F4 A2 00 2D 1B 47 F4 A3 00 2D 20 47 F4 A4 00 2D 21 47 F4 A5 00 2D 29 47 F4 A6 00 2D 2A 47 F4 A7 00 2D 2A 47 F4 A8 00 2D 2B BB 31 0D DA CA 00 3C E3 0D D7 CA 00 CC E2 BB 33 0D D3 BB 31 CA 00 82 E2 E7 FE 55 00 BB 63 B7 48 B7 B7 E7 FE 55 00 BB 5E 0D C7 BB 25 CA 00 82 E2 E0 02 F4 41 02 00 F6 F2 B4 FE E7 FE AA 00 0D F3 BB 1A CA 00 AA E3 0D E3 BB 16 BB 67 0D E0 BB 13 CA 00 9C E2 0D DC BB 0F CA 00 AC E2 0D D8 A9 E1 09 E1 0D E1 88 10 88 20 E6 F1 00 E6 2E (transferData)
Received: 01 76 77 (transferData ACK)
Sent: 00 FF 36 E1 14 B9 41 E7 F4 7F 00 0D 08 88 10 88 20 E6 F1 00 E6 E1 14 B9 41 E7 F4 76 00 E4 41 01 00 BB 1C 0D 18 88 10 88 20 88 30 E6 F1 00 E6 BB 28 E0 02 F1 4E F1 6E B9 E1 08 11 BB 2A 48 60 3D 09 B9 E1 01 6E 08 11 A0 02 3D F8 21 6E 41 6E 2D 01 E0 26 98 30 98 20 98 10 CB 00 88 10 88 20 88 30 E6 F1 00 E6 E0 02 A9 41 E1 06 99 E1 01 6E BB 05 A0 02 3D FB F1 E6 BB 01 0D EC F7 FE B0 FE 0D 00 A7 58 A7 A7 9A B7 FC 70 F2 F7 B2 FE 7E B7 CB 00 88 10 E6 F1 FF FF E0 06 A7 58 A7 A7 8A B7 04 70 A0 01 3D FA E0 16 0D 03 F2 F7 B2 FE 7E B7 0D D3 8F E1 8F E0 9F E1 9F E0 BB 66 BB 65 BB 23 E7 FE AC 00 BB 46 BB 32 E1 0E BB 43 BB 2F BB 23 BB 1A E7 FE AD 00 BB 3D BB 29 E0 05 E6 F2 FE 01 E0 75 BB 52 A0 05 3D FD BB 3F BB 2C BB C7 A0 02 3D F7 BB 3A BB C3 9F E0 8F E0 BB 4A 9E E0 BB 48 8E E0 98 (transferData)
Sent: 00 FF 36 BB 46 0D 08 8F E0 9F E0 BB 42 8E E0 BB 40 9E E0 BB 3E CB 00 8E E0 BB 3B 9F E0 BB 39 8F E0 CB 00 BB 36 9F E0 BB 34 9E E0 CB 00 E0 07 8E E1 BB 2F 9F E0 BB 2D 4A E0 F7 80 9E E0 BB 29 8E E0 8F E1 CB 00 8E E0 BB 24 9F E0 BB 22 9E E0 BB 20 CB 00 88 10 E0 71 5C 87 5C 17 4A 88 E0 18 BB E1 A0 01 3D FA 8E E0 0D 54 88 10 8E E1 E0 71 E0 07 9F E0 BB 0E 5C 17 4A E0 F7 80 9E E0 BB 09 A0 01 3D F7 8F E1 8E E0 0D 44 88 30 E6 F3 00 01 0D 02 88 30 E0 73 A7 58 A7 A7 28 31 48 30 3D FB 98 30 CB 00 BB B1 E6 F7 AC 00 BB D4 BB C0 48 70 3D F9 0D 07 BB A9 E6 F7 AE 00 BB CC BB B8 48 70 3D F9 CA 00 7C E1 BB C6 BB B2 CA 00 7C E1 BB C2 BB AE 0D A2 88 10 88 20 88 30 88 40 E6 F3 00 E6 E0 02 F4 43 02 00 F4 33 03 00 F4 23 04 00 E0 04 A9 83 28 44 7C 14 28 41 08 35 A7 58 A7 A7 99 E3 99 F3 0B (transferData)
Sent: 00 FF 36 BB 09 08 12 18 20 A0 04 3D F7 98 40 98 30 98 20 98 10 CB 00 88 10 88 70 E6 F1 AA AA E7 FE AA 00 CA 00 22 E4 E6 F1 55 55 E7 FE 55 00 BB 7D E6 F1 AA AA E7 FE A0 00 BB 78 98 70 98 10 BB 7B BB 65 CB 00 88 10 88 20 88 30 88 40 88 50 E6 F3 00 E6 E0 02 F4 43 02 00 F4 33 03 00 F4 23 04 00 E0 04 F4 83 05 00 09 81 B9 83 08 31 E7 FE 36 00 B9 E3 08 31 29 81 BB 0A B9 E3 08 31 08 11 18 20 A0 04 3D F9 CA 00 56 E1 98 50 0D C0 88 10 A7 58 A7 A7 BB 04 66 F1 FF 3F A9 E1 0D BB 88 10 88 20 5C 22 66 F2 FC 00 1C 21 68 13 70 21 F6 F2 00 FE 0D AF 88 10 88 20 88 30 88 70 E6 F3 00 E6 E6 F2 20 00 E6 F1 AA AA E7 FE AA 00 BB 2F E6 F1 55 55 E7 FE 55 00 BB 2A E6 F1 AA AA E7 FE 80 00 BB 25 E6 F1 AA AA E7 FE AA 00 BB 20 E6 F1 55 55 E7 FE 55 00 BB 1B E6 F1 AA AA E7 FE 10 00 BB 16 CA 00 9E (transferData)
Sent: 00 49 36 82 E2 E7 FE 80 00 BB 02 98 70 0D 81 88 20 88 70 26 F2 18 00 F1 FE 67 FF 80 00 BB B8 67 FE 80 00 41 EF 3D FB 98 70 98 20 CB 00 88 10 BB B7 66 F1 FF 3F B9 E1 0D 05 88 10 BB B1 66 F1 FF 3F B8 71 98 10 CB 00 17 1C E1 E3 02 (transferData)
Sent: 02 31 02 35 (startRoutineByLocalIdentifier)
Received: 03 7F 31 22 D5 (startRoutineByLocalIdentifier NAK conditionsNotCorrectOrRequestSequenceError)
Sent: 01 A6 A7 (166)
Saved EEPROM to EDC15_EEPROM.bin
Sent: 01 A2 A3 (162)
Reboot successful!
SKC: -00001
Immo is On ($33, $33)
gmenounos
Watertown, MA, USA
.NET Version: 5.0.8
Culture: en-US
Reading sync byte
Reading sync byte
Reading sync byte
Unfortunately, there's not much I can do since I don't have any "BOO" Bosch/Motometer clusters to test with. It doesn't appear that they were even sold in the USA, so I can't pick up a cheap one from the junkyard or eBay.
You can try VAG EEPROM Programmer: https://www.drive2.com/l/9288217/
Rjbiga
Kampala, Uganda
Vw Gold MKIV
Thanks for the effort. Am really intrigued by your drive and initiative in all this!
I will try the link and should, hopefully report positive results.
Rjbiga
Kampala, Uganda
Vw Gold MKIV
Indeed the results are positive. I was able to get my car's SKC using the VAG EEprom Programmer
Really appreciate your help!
