If it’s a diesel tank, I’d target the VR6 B4V owners. With today’s fuel prices, nobody may want it, lol.
-Todd
I disagree...the wagons used the same size tank regardless of fuel, the difference between a VR6 wagon tank and a diesel wagon tank is the hole for the fuel pump on VR6 cars vs the sender on a TDI car. Well and the inlet restrictor too is different on VR cars (unleaded fuel).
The tank from the 16v B3 wagon is identical to the B4 TDI wagon tank except for fuel restrictor, and somewhere I have a pic comparing the two. And I found them:
This is comparing (on the left) a 1990 B3V 2.0L 16v gas fuel tank with a 1996 B4V TDI fuel tank, they are the same tank, which is actually kind of nice however I'd already bought the TDI tank so oh well. The only difference is the fuel restrictor in the neck used for unleaded fuel, otherwise I see no difference in them. The B4V VR6 fuel tank is the same size as both these but has a much larger opening for the drop in fuel pump / sender unit, like that from a Mk3 gasoline powered car.
Steve
EDIT : Personally if I was in a position to get it I would...just because a TDI tank from a wagon is good to have just in case you want to convert some dead VR6 wagon over to diesel.
I wasn't aware that it was technically classified as a 26.4 gallon tank, VW never says that in the owners manual to the best of my knowledge, at least not in the 1990 owners manual. And online it says all the B4 cars had the same size tanks, 18.5 gallon.
