Forced regen procedure???!
Kyle.kratz78
Elkridge md
12 jetta tdi
I keep trying to activate the forced regeneration through vcds. It tells me to hold the brake 10 times. I hit the brakes once and the prompt immediately switches to full throttle. I do that and it will either abort or go back to prompting the brake. Am I being dumb about this or what is tells issue? Any help would be fantastic
TurboABA
Kitchener, ON
Probably.... but we can't see anything you're not showing us.
How about we start with, why are you wanting to force a regen instead? :unsure:
Kyle.kratz78
Elkridge md
12 jetta tdi
Lol thanks. Dpf is clogged out it's bum. Mk6 kid brother got off marketplace last week. Would rather not pull the exhaust as it's a giant pain.
TurboABA
Kitchener, ON
That doesn't compute.... you could be well over what the controller will allow you to force anything onto.....
Post scan, visuals, something... you're not saying much, and you're definitely not showing anything.
Kyle.kratz78
Elkridge md
12 jetta tdi
What I was hoping for is for someone to know the correct procedure on vcds to start a forced regeneration on a mk6 jetta. Not particularly looking for recrimination on why im not giving the correct information. I just want to k o
Kyle.kratz78
Elkridge md
12 jetta tdi
TurboABA
Kitchener, ON
I was hoping you'd answer some very important questions. Oh well, best of luck.
Kyle.kratz78
Elkridge md
12 jetta tdi
My bad my friend. I get awful grumpy when I'm hungry. When I get off I'll try and see if I can get some answers for you
Kyle.kratz78
Elkridge md
12 jetta tdi
Edit with the Docs app
Make tweaks, leave comments, and share with others to edit at the same time.
NO THANKSUSE THE APP
https://drive.google.com/u/0?usp=docs_web
Log-JACOBS-3VWLL7AJXCM376059-214190km-133091mi-1-1
Friday,21,March,2025,17:58:50:06142
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
www.Ross-Tech.com
VIN: 3VWLL7AJXCM376059 License Plate: JACOBS
Mileage: 214190km-133091mi Repair Order: 1
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 47 56 77
VIN: 3VWLL7AJXCM376059 Mileage: 214190km-133091miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 26971 003 1048576
VCID: 382927A07E52F42A777-806C
VINID: 0E69DC70745AA137431C600524EB3A5726
3 Faults Found:
011174 - NOx Emissions Exceeded
P2BA6 - 000 - SCR Catalyst Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 214198 km
Time Indication: 0
Date: 2019.08.12.
Time: 03:20:57
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 980.1 mbar
Temperature: 13.5°C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 26.1°C
009315 - Particle Filter
P2463 - 000 - Excessive Soot Accumulation - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 214198 km
Time Indication: 0
Date: 2019.08.12.
Time: 03:20:57
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Pressure: 0 mbar
Hex Value: 0xFF01
Temperature: 168.0°C
(no units): 0.0
Mileage: 640 km
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 003 - Implausible Signal
Freeze Frame:
Fault Status: 01100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 214198 km
Time Indication: 0
Date: 2019.08.12.
Time: 03:20:57
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.93 V
Lambda: -11.8 %
Lambda: 9.5 %
Bin. Bits: 00000000
Voltage: 0.304 V
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AT
Component: GSG DSG AG6 541 9430
Revision: 06454104 Serial number: 00002102030469
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 1471B310027AF04A3BF-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492900008D0B02E992220042A71000
Shop #: WSC 00066 000 00000
VCID: 7DA7F6B41DF01102E41-8028
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 214186 km
Time Indication: 0
Date: 2019.08.12.
Time: 01:42:49
Freeze Frame:
Count: 3
Count: 12
Count: 29184
Count: 16390
Count: 50944
Count: 0
Count: 1535
Count: 0
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 30
Mileage: 214186 km
Time Indication: 0
Date: 2019.08.12.
Time: 01:42:49
Freeze Frame:
Count: 3
Count: 12
Count: 29184
Count: 64
Count: 50944
Count: 0
Count: 1535
Count: 0
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000758030
VCID: 6FBBDCFC4B9C739266D-803A
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 214186 km
Time Indication: 0
Date: 2019.08.12.
Time: 01:42:48
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0257
Revision: B2066001 Serial number: 04371021120672
Coding: 7B994B9A08AB0B0008382000240884C50082502E60000000300000000000
Shop #: WSC 30085 002 1048576
VCID: 2F3B1CFC871C339226D-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Serial number: --------------------
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0003Z49L
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0896551
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM03WGB3 Dataset Number: 160003v____ 0154
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 343113906EBA104A5BF-8060
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000B3DU0R
Coding: 303036
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME316C2267ZZZW
Crash sensor for side airbag: passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME55596166ZZZ.
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME4B4D1116ZZZU
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME35652116ZZZJ
3 Faults Found:
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [10001001] - Open or Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 214186 km
Date: 2025.03.21.
Time: 01:42:51
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [10001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 214186 km
Date: 2025.03.21.
Time: 01:42:51
9483008 - Seat Occupied Recognition
B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 30
Mileage: 214186 km
Date: 2025.03.21.
Time: 01:43:29
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Serial number: 00000000000000
Coding: 270A01
Shop #: WSC 00066 000 00123
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 290FF2E4B9785DA2F89-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0257
Revision: B2066001
Coding: 102200
VCID: 70B9DF805AA26C6A7F7-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0604
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DCDE87CFE96BA313-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661231825
Coding: 010000
VCID: 290FF2E4B9F85DA2F89-807C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 70 3301
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 35372E94694009426C1-8060
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 214186 km
Time Indication: 0
Date: 2019.08.12.
Time: 01:42:48
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 38.0°C
RPM: 826 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225311001663 Dataset Number: 560050v____ 1604
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 30391F809AA22C6A3F7-8064
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3245656
Coding: 01020000010006
VCID: 6393A0CC9B54C7F2F25-8036
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661494289 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BF4DCAF6C6BD2EED-8072
End----------(Elapsed Time: 01:26, VBatt start/end: 12.0V/12.1V)-----------
------------------------------10 Faults Found------------------------------
Kyle.kratz78
Elkridge md
12 jetta tdi
So measuring block 075 is fuel rail pressure not the particle filter as far as my uneducated mind can see. Found a few for particle filter block 108, 107,106, 105, and 100. Group 108 field 1 is particle filter pil ash load which is 30m1 ml. Field 2 and 3 are carbon mass but they are blank. I cannot find a way to post pictures from my phone to the forum however to make this easier. Do I have to go through like Google Docs or some such?
TurboABA
Kitchener, ON
So like I said, you did NOT read the information that was provided to you! Perfect! (y)
Kyle.kratz78
Elkridge md
12 jetta tdi
You going to be helpful or just troll some more bro. I read everything. I'm just stating that it wasn't that. And then I gave suggestions as to what blocks it may be instead of that, as it says for the UDS it could be different locations and such. Chill or be helpful dude.
Kyle.kratz78
Elkridge md
12 jetta tdi
108. And it says Look at 241.2 and 241.3 if block 108 fields are blank. I didn't see that before. Thank you. After work I'll try this again
Kyle.kratz78
Elkridge md
12 jetta tdi
Block 241 field one isparticlw filter ash volume of 30ml. Field two was 43g soot load calculated. Field three for measured soot value is just blank
