andreigbs
In the interest of making sure my PD has all the air in needs when I request max "GO!" I decided to check my EGR valve, you know, just to see what the general condition of the intake is. I have only 53k miles on her, been using ULSD since about 35k miles, so it shouldn't be so bad, right?
Wrong. Took out EGR valve (3 little 6mm hex bolts) and what do i find? The plunger was all carbony-gooey and stuck, almost completely blocking ANY air from entering the intake. Some of the yucky stuff fell out as I slid the EGR valve out, whatever was left inside I scooped up so as not to get it sucked in. The intake looks like it could use a cleaning, but it's not bad yet. I think at the first TB change.
Anyway, cleaning out the EGR valve with a can of carb cleaner, bristle brush and some fine sandpaper, got it to look as new. Plunger moves smoothly, slid the valve back in the slot, bolted it up, started her up and all I hear is smooth idling. So I get cleaned up and take it for a spin.
The top end is now alive! The car revs up happily to 4k rpms, the boost is steady as a rock at a hair over 15 psi and when i come to a stop, NO MORE SHUDDERING! Couldn't believe it, and also no more slight smoke at WOT, not even at night in the headlights behind me. The cleaning was a MUST, and it did wonders for my PD; i can only imagine i'm not the only one. using ULSD exclusively, I'm curious what the EGR valve will look like at 100K miles when I'll do the TB.
So before you guys go changing your MAFs and your air filters hoping to regain any lost "oomph", take off the EGR valve and see what's up because you may just be horrified. It brought back memories of my first intake cleaning, all i can say is I don't look forward to another, but such is life.
