Foor modules NB
1975 Kombi
Acton, Ontario, Canada
2003 TDI Jetta, 2011 Touareg TDI, 1992 D Jetta, 1992 TD Jetta, 2001 NB TDI, 1992 Golf coupe D
Door modules 2001 NB
OK I have a few issues and looking for what door modules handle what components. ie: power window module and door latch module
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AR
Component: 7S Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00066
VCID: 0E13A0E94A75EE3F25-4B00
Subsystem 1 - Part No: 1J2959802C
Component: 7S Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J2959801D
Component: 7S Tõrsteuerger. BF0002r
3 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 180 E
Component: RADIO 3CP 0002
Coding: 00401
Shop #: WSC 00066
VCID: 1A3BDCB986BD329F49-4B00
1 Fault Found:
00853 - Loudspeaker(s); Rear
36-10 - Open Circuit - Intermittent
I have replaced both door latches and they work well now but 01329 error says something is wrong with the door module.
Any direction will be appreciated.
Both your mirror heaters are dead (common, because people leave them on all the time and they burn up), and the data bus CAN system may be in one-wire mode instead of two. You can see this somewhere in the CCM's data blocks (I forget where).
The CCM and the door modules (the door module is integral with the window lift motor) have their own dedicated paired wire communication network. You may have a bad door module (unlikely, but possible) or a bad door harness (more likely).
1975 Kombi
So possible break in wire going through the door jam? All things work. Alarm/windows/locks.
