Thanks for quick reply.You should be able to just power up the two pins for the folding motor at the plug with some appropriate jumpers to test it. That will eliminate that as the problem at least, then look further.
RTFM! RTFM! ;-)Hello,
Following this great thread I installed foldable mirrors (second hand), recoded CCM and upgraded power window motor with necessary TLE 6208-3 chip.
Left mirror is folding/unfolding with no problem, but right is totally dead (no movement, no sound).
Yes, I'm stupid - forgot to check mirror before installation
Now I want to know where problem is.
Bad connection, bad wiring, blocked/broken mirrors motor, broken chip....?
Is there option to diagnose the foldable mirrors with VCDS through measuring blocks and adoption?
Regards
On vehicles with can-bus, this is totally normal! Plus it increases aerodynamics at 200+!!!! !!RTFM! RTFM! ;-)
I recoded only driver's module. Just forgot to recode passenger's module.
Now everything works perfectly ;-)
Is it normal that I can fold/unfold mirrors if I start to drive the car ( even at speed over 60km/h)?
Guys, the help would be really appreciated. Please, if anyone knows how to program the CCM device without COM-KKL adapter any info would be helpful.
Yorosiku onegai itasimasu!
