The goal was DIY fogs for about $75 each complete.
I looked at the items from various vendors and thought $400 plus for a complete setup was a bit steep for something as simple as 9006 halogen fogs, which would include: fog kit, wiring harness, euro switch and trigger wire. I researched many posts on the subject.
I decided to go the ebay buy it now route that included shipping.
I used 3 different vendors two USA (euroswitch, & wiring harness) and one offshore, China, for the fog light assy.
The chromed trimmed euro switch (not shown in the fotos) was $50 and had a made in Mexico stamp with VW logo and part no.
The trigger wire I made myself out of some stranded wire.
The offshore fog light assy was $80 - BTW: I ordered it on Sep 6 and it arrived Sep 17. The wiring harness was $13. Here are the fotos of the parts.
1. Wiring Harness with 40 amp relay and shrouding on all wires. It was generic for 9006 bulbs but the length fit perfectly with nothing too short or too long. There's a ton of these from different vendors. Even if you decide to make your own, you'd be hard pressed to snag the connectors alone for under $15.
2. Here is a close up of the 9006 connector -- keyed and with a hold down to clamp onto the 9006 bulb housing. A soft yellow gasket surrounds the 9006 connector which makes for a weather resistant seal when plugged in.
3. The 25 Amp fuse is in a hinged housing that contains a plastic mount so it can be attached to a straight clip.
4. The 40 amp relay shows what I guess to be an epoxy sealant around the pins, and fits securely in its connector. Being its connectorized means you can change it out to a Bosch or any other brand you desire as the 30, 87, 86, 85 pinout is standard on these relays. Also, the relay like the fuse, can be mounted onto a straight clip.
5. Plastic grill -- fit nicely and matched the center grill.
6. FWIW -- VW part no. on grill.
7. Projector housing contains adjustment screw and there's a hole in the grill so adjustments can be made on the car with a 6mm allen wrench. I changed both bulbs out and used a "brand" name item instead of the bulb that came with assembly.
8. FWIW -- Part no and Logo on housing
9. Before
10. After
9. Before
10. After
