So Ive been pouring over all these threads, some good stuff in here:
http://www.bmw-m.net/TechProc/bleeder.htm
http://www.audiworld.com/tech/misc24.shtml
http://forums.vwvortex.com/showthread.php?3183602-DIY-Brake-Flush-MK4&p=73128466
http://forums.tdiclub.com/showthread.php?p=480733
http://forums.tdiclub.com/showthread.php?t=330533&highlight=brakes+flush+diy
But.... I dont think I want to use or make a Motive speed bleed. I just want to do it the good ole' fashoned way..
I know there are two methods I can use:
1) the open up all the bleeders method and let it slowly sep out.
- my Question on this is do I also just open the clutch bleeder and will it just sep out until it turns blue?
2) The pump the brakes method: where I start by opening the rear bleeders and work my way to the front and ending with the clutch.
-Question on this is I know pumping the brakes pushes the fluid out the brake bleeders, so would pumping the clutch push the fluid out the clutch bleeder? and is that the right order or should I bleed the clutch first to avoid mixing with the old fluid?
