Rrusse11
At that speed, drag is your major factor, not engine rpm IMO. Doubt if you'll see more than 1mpg.Will help economy then
I beg to differ, the manual trans for the same car I have sits at 2000/2100 rpm at 70mph where as i sit at 2200/2300rpm right nowAt that speed, drag is your major factor, not engine rpm IMO. Doubt if you'll see more than 1mpg.
That's why I should have gotten larger tires.I beg to differ, the manual trans for the same car I have sits at 2000/2100 rpm at 70mph where as i sit at 2200/2300rpm right now
The manual gets considerably better MPG at 70mph than i do. like mid 40's vs high 30's
ALooking at purchasing a Fluidampr crank pulley for my 2006 Golf BEW. The car has a SMF and the chatter and gearbox noise is getting to me. The Fluidampr website says their product #551201 is for the 1.8T engine. Online retailers are selling the same part number and saying it fits the TDI engines.
Do the engines share the same crank pulley? Wondering why Fluidampr wouldn't market the pulley for the TDI engines.
Thanks in advance.
Good thing the DSG isnt a slushbox one of the key selling points of using the DSG in a TDI is that theyre just about as efficient as a manual, as it is quite literally an automated manual. the only fluids dealt with in this trans is the oil used to actuate solenoids and lubricate the friction plates, this nets in near zero efficiency loss compared to a manual (according to vw)A slushbox loses a lot of energy
I have 225/45r17 right now, going to go up to 225/50r17 once ive let these run their courseThat's why I should have gotten larger tires.
You must not know about FCP euro then hahaIt is recommended though that you change the fluid every 40k miles, not cheap
using the correct oil
I might have to put one on my Tacoma, it shudders below 1600rpm if loadedYay for the fluidampr. Per @Whitbread 's advice, drained my nasty looking GL4 last night, ran the car around 10 minutes in 4th/40-45mph with the cheapest ATF I could get, drained that crap, put in Redline Lightweight Shockproof (aka smurf's blood), and the clutch chatter was super quiet. Installed my fluidampr like 40 minutes ago and holy crap. Clutch chatter? What's that!?
Time for the obligatory test drive (gotta pick up a tire I took in yesterday for flat repair).
The first thing that made the huge difference was going to the Redline Lightweight Shockproof, and then everything got totally quiet with the Fluidampr. No difference now with the clutch in or out, but it's so much quieter, too.I might have to put one on my Tacoma, it shudders below 1600rpm if loaded
