Flickering infotainment screen
Phil Ritter
Sammamish, WA
2017 Golf
The screen flickers and moves around but all the functions work.
I have done the reset, disconnected and re-connected the battery, jumpered the battery terminals and have tried three used screens and a replacement 5F control unit from EBay as well as running the dealer diagnostics.
pedroYUL
MI, USA
2004 wagon BEW; 2015 Passat CVCA; 2015 GSW CRUA
Typically flickering or blank screen traces back to a faulty "brains" unit, as the screen is merely a screen
Cuzoe
Los Angeles
MK7 Golf S
@smittyatl I wouldn't normally say a flickering screen is a harness. I would normally agree with @pedroYUL the main unit is failing. But OP says they've already tried a few used screens and replaced the 5F unit (which to mean means the main unit in the glovebox).
Of course there's no guarantee with anything used. I think the likelihood of 4 screens having the exact same issue is slim. Likelihood of 2 main units having the same issue is 50/50, so it's very possible the eBay unit has the same problem. I would try to source another one.
The cables are cheap though, and good to rule out. I haven't really heard of cables failing but the more you mess with them (in removing/installing parts to troubleshoot) the more chances you have to mess one up.
franklinstower
Kirkland, WA
'04 wagon
Etoile
NY
2009 Sportwagen no longer 2011 Jetta Sportwagen 2015 TDI Golf Sportwagen all manual
Have you found a remedy for the flickering screen? Same issue here. Wondering if it’s possible for the cause to be something other than just failure.
