I have a 2003 alh automatic engine that I am putting in a small jet boat. It came with a thin flex plate and a torque converter with the ring gear. The starter is mounted on the transmission side. I need to attach a drive line directly onto the flex plate that will drive the jet.
My questions are: is there a flex plate or flywheel that has the ring gear on it that is thinner and has access to the crank bolts so I can attach a small adapter for the driveline. Also, I want to attach the starter higher or on the engine side and need a plate or adapter.
Space behind the engine is at a premium but the sides have unlimited space.
I am attempting to get some photos to make this clearer but I am guessing that this has been done before and I just can find it.
Thanks, Matt.
Thanks, Matt.
