ejallison1
- Joined
- Apr 28, 2010
- Location
- Kansas, Illinois
- TDI
- 98 Jetta TDI AHU, 97 Passat TDI AAZ, 04 Golf TDI PD, 01 NB TDI ALH
I had a flashing glow light about a year ago on my B4 sedan which resolved after installing a new brake light switch. The glow plug started flashing again a month ago . Looking for suggestions on what to do or where to look for a solution. Here is what I've done so far. Haven't noticed any issues with the car's preformance. It is stock.
I again changed out the brake light switch and this time changed out the blue switch (assoc. with the cruise control) that is located immediately above it. Very difficult access!
I also changed out the switch on the clutch pedal.
All switches were new and checked with a a multimeter prior to installation and everything is working as it should. Cruise control works and cuts out when brake or clutch pedal is depressed. Brake lights working and are regular incandescent type.
I have VAG Com and went to group 6 which shows the switch functions. 011 is displayed initially and when the brake is depressed the numbers change to 000. When the clutch pedal is depressed the first of the three digits changes to 1. I do not have any trailer light wiring.
Vag Com shows the following on autoscan.:
Address 01: Engine Labels: 028-906-021-AHU.lbl
Part No: 028 906 021 FA
Component: 1,9l R4 EDC G10SG 1453
Coding: 00002
Shop #: WSC 25121
VCID: 53AB808CA184FD1EFE-4B00
3 Faults Found:
01268 - Quantity Adjuster (N146)
35-10 - - - Intermittent
00741 - Brake Pedal Monitoring
27-10 - Implausible Signal - Intermittent
01050 - Glow Plug Monitoring
35-00 - -
Readiness: N/A
Address 15: Airbags Labels: 6N0-909-60x-VW2.lbl
Part No: 6N0 909 603 G
Component: AIRBAG VW2 V00
Coding: 00071
Shop #: WSC 00046
VCID: 366DD9181236C836F9-4B64
2 Faults Found:
00532 - Supply Voltage B+
06-10 - Signal too High - Intermittent
07-10 - Signal too Low - Intermittent
Checked the QA on VCDS and it showed 4.4-4.6mg/str which is where I had it set after the last timing belt change
Checked timing and it is 1/2 way between the upper and middle line on the graph.
I visually inspected the wiring on the 3rd injector as I had read it could be the cause for a flashing glow plug light. It looks OK.
Checked the glow plug harness and the glow plugs. Two glow plugs replaced and the harness appears good-no cracked insulation etc. and the autoscan above was done after I changed the two glow plugs. Can't remember if I cleared the codes.
Thanks in advance.
Coding: 00002
Shop #: WSC 25121
3 Faults Found:
35-00 - -
Readiness: N/A
Coding: 00071
Shop #: WSC 00046
2 Faults Found:
Thanks in advance.
