has anyone had a problem with installing led bulbs in the tail light housings on a tdi, I ordered 6 bulbs from superbright led.com 2 narrow red 67-R9 for the parking lights and 4 narrow red 1156-R12 for the turn and brake light. Immediately after I installed the bulbs the glow plug light started to flash. I have not had any problems with the glow circuit for about 2 yrs after I replced the harness and glow plugs. If I change the bulbs back will the glow light go out or do I need to clear the computer? I have a 01 TDI Golf ALH 1.9 Thanks Rob
The flashing glow plug CAN mean that your brake lights aren't working. Stupid I know, but I've seen it. Seeing as how you got LED's...did you get load resistors for the dual watt bulbs? ie - blinkers/brake lights? If not, then that's your problem. Got back to superbright LEDs.com and order a load resistor for each blinker and brake light. So, if you did front and rear you'll need 6. If it's just a marker light or a light that doesn't blink, then you
won't need a load resistor for that.
All my exterior lights are LED. Thankfully my aftermarket brake lights were already LED so I didn't have to worry about them. Let me guess, do you have "hyper blinkers" too? The LEDs run on a lower rating than regular bulbs do. So the normal system thinks that the bulb is burnt out. That's why you need the load resistor. And for some stupid reason, VW thought it would be a good idea to have the glow plug light flash if the brake lights aren't working...
Have someone press on your brakes and you look...see if they light up. They might, but your car thinks they aren't. Hope that helps!
