TurboABA
It's 1000w.... just looked it up.
On some models, you can do tests on it using VCDS
Here you go. Proof of a coolant heater.
Coolant and air are not the same.
Please educate yourself on the subject if you're going to make these statements.
If you want to prove your statements, please supply sources (SSP, VAG documents, etc) not personal opinions, fake news, conspiracies, etc.
I'm calling you out on this because if I'm in the dark or wrong, I want to be educated on it.
And yes. It's not the computerized HVAC. It's the manual one. Electric actuators obv. But there's no temp setting. Just high/low on the dialsOn what? Please supply diagram if possible.
Was the '13 JSW TDI available down there with manual HVAC?
Just mounting, plumbing, wiring, and coding.Anyone know what it takes to rig up a Webasto to work as if it were VW factory installed, like the Euro market cars? Anyone done this before?
I see a lot of the components, like the custom molded coolant hoses, aren't available from VW USA.
