Just wanted to share a fix I came up with for a leak I had at the DSG mechatronic plug — specifically from the small vent pinhole that. I know a few others have run into this issue, so hopefully this helps someone.
The leak was slow but persistent, and after some inspection, I found it was coming right from that tiny vent hole. I verified this by adding air into the system from the vent at the top of the transmission. Rather than replacing the mech unit, I tried a simple solution that’s held up surprisingly well.
Here’s what I did:
I know this might not be the "official" fix, but it worked well for me, and it’s a quick, inexpensive option for those dealing with the same issue.
Let me know if anyone has questions or has tried a similar approach!
Here’s what I did:
- I used 1/16" thick rubber from a pack of plumbing gasket sheets (you can get these at most hardware stores).
- Cut a small circle that fit neatly inside the circular recess of the mechatronics plastic — basically around the pinhole.
- Placed the rubber piece over the pinhole and reinstalled the plug. The pressure of the plug itself holds the gasket in place.
