sourmash said:
Thank God for the new tire inflation sensors, as it alerted the wife of the low pressure and she went straight home and parked before it got to low.
Do
not use fix-a-flat on this vehicle. If you have a tire pressure monitor you should never use any kind of stuff like that. You should tell anyone who is working on your car that it has the monitors, letting them know can save you a lot of money. On many designs you cannot tell outwordly that it has them.
The monitors are installed in place of conventional tire stems and on most older designs they look like fancy chromed stems, on the newer designs they look just like regular, rubber stems. The only clue is the monitor on the dash that lights up for a second when you start the car ( assuming you are looking for it ). The gook from the fix-a-flat will ruin the monitor. A new monitor is $80-$150 per tire, plus installation, plus the computer has to be reprogramed. Also most tire shops and parts stores don't stock the peices.
Also, remember, if you have your tires rotated the computer has to be reprogramed. Ask the shop first if they know how, nearly every car has it's own special procedure and special tools are required. The shops that know what they are doing also know they have to charge for this service (no free tire rotation). Any time you touch one of these things it is possible for it to fail, fixing a flat or installing a new tire requires messing with them because of their location, if it fails it is
not the mechanics fault in most cases, don't expect them to eat it.
Sorry for the long winded post.
