FIS cluster(Immo III) in an Immo II car, miles to empty
tongsli
Baltimore, MD
Nihilator said:
Yeah, that's correct. When I fill up, the distance-to-empty screen will say anything from 420 to 470 miles, depending on the type of driving I've most recently been doing. It will adjust itself as I get closer to empty, so it doesn't end up being off by the time I get to the end of the tank.
My light will come on when distance-to-empty says 25 miles. That's not wholly accurate, because I usually have about 50 miles before I'm at what *I* call empty.
--Chris
470 miles? That's it?;)
tongsli
Baltimore, MD
Nihilator said:
90 stock horsepower? That's it?
--Chris
C,
I'm actually at 125 at the wheels the last time I dynoed so at the engine would be closer to 150. Still not at 1.8T levels but at a range of 650-700 miles per tank, I'll take it! And, you won't catch me hanging out in the power enhancement section. I'm past that phase now.
L
Jump62
Crofton, Maryland
2003 Jetta GlS,2006 NB (Crew Chief),2009 JSW
tongsli said:
C,
L
Sure Lito and when VW offers the first autobahn rated warp core and duotronics Ecu Dilithium enabled it would soon be grafted on your car:rolleyes: . When does this madness stop?
Paul
aka Jump62
BlueCTTDi
Manchester, CT
2004 Golf GLS (PD) - Indigo Blue
I bet this would work great on my cluster except it's the new software that won't allow me to adapt the consumption rate *grrrr*.. so i trust enabling the MTE function would probably give me rather inaccurate readings, since i'm already burning fuel about 14% off from what the cluster is telling me...
ugh.
pheller
Boston, MA
Jetta GLS 1.8t, 2003, Platinum Gray
mickyTDI said:
What are the addresses tht are to be changed to activate the range to empty? or is it top secret?
Code:
das "Restkilometer-an-Byte" im EEprom:
0x0416 = C1 Restkilometer aus  (off)
0x0416 = E1 Restkilometer an (on)
Dieses Byte steht bei VDO Tachos 825er, 845er, 826er und 846er.
No guarantees, of course. Reader takes responsibility, etc., etc.
--phil
TDi110
Planet Earth
So how can I load the latest software version into my 919 immobilser II cluster, its currently on V1 which when the language adaptation is set to NO TEXT 000007, only displays 1 measurement value. ie average MPG or distance, time etc.
I would like the display to show data like the later clusters ie measured value and temperature.
What do I need to have to do this, can I do this using the vagcom lead.
What do I need to have to enable miles to empty?
Cheers.
Dubster
delvi__acevedo
Mod'aholic
Milford, PA ,USA
Getta GLS,2001,silver
Cheers.
Dubster
I have the same problem, and MTE will not work on Immo 2:cool: look at post 2 thru 7 on page 1.
Nison
Ottawa
PASSAT
I have a 2000 Passat with a half FIS and single DIN, is it possible for me to upgrade it to full FIS?
mtltdi
Canada
2003 Golf GLS, Indigo Blue
My Full FIS is actually from a German Passat with Immob III so I assume you can do the same. Got it reflashed as a 1J5 920 846C and it works perfectly.
mtltdi
Canada
mickyTDI said:
mine is activated and was set to E1, but for an experiment i changed it to C1 and the range was still there..
Did you unhook the battery to reset the cluster? Mine worked fine, but with the old characteristics until I unhooked the neg terminal on the battery for about 1 minute.
