CrazyMonkey
Hi all,
I finally upgraded my ancient laptop and almost-as-ancient VAG-COM cable (old KEY-COM). I scanned my car and picked up a few codes, which isn't terribly surprising. The summary followed by the modules with codes is below (cut out the data for the modules with no codes). Before I clear the codes, do any of these strike anyone as concerning?
I can probably explain a few of them (had to reset the driver's side auto up/down on the window for instance), but the CAN Gateway fault was a surprise to me...
Any insights would be appreciated. Thanks!
Wednesday,03,October,2018,18:43:48:41913
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
www.Ross-Tech.com
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75
VIN: 3VWFA7AU0FM508747 Mileage: 69489km-43178miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582502150778
Coding: 005108464041826969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 07031
ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
ROD: EV_BCMBOSCH_014.rod
VCID: 4ACD618CFC3532C7EF0-801E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150112 043 0581
Serial number: 150327193057
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y15M02D06H01M33S09
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST00044RKJ00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST00044RVU00000
Coding: 191800
1 Fault Found:
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 163
Reset counter: 204
Mileage: 63852 km
Date: 2018.06.04
Time: 19:02:09
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 01031510001750
Coding: 0901000800087300EF000008080F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011_VW37.rod
VCID: 71BFD660B123211F8EA-8024
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29150000468700095105
Coding: 30FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0023493
1 Fault Found:
66565 - Diagnostic Databus
U1202 00 [008] - Malfunction
[Bus defekt CAN-Diagnose]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 177
Mileage: 68207 km
Date: 2018.09.03
Time: 11:17:11
Supply voltage: Terminal 30: 12.6 V
Terminal 15: OFF
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 110315060506N2
Coding: 003013200000040000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3E253D5CB0FD8E67438-806A
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000890438
Coding: 011000
1 Fault Found:
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 68874 km
Date: 2018.09.25
Time: 18:53:58
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B02702153082
Coding: 027302000000000021220002001800001F0100340100010002
ASAM Dataset: EV_MUStd4CPASE 002040
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 6491AF347ED184B7F5C-8030
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS50177Y
1 Fault Found:
0023 - Tuner for Satelite Radio
B11CF 96 [008] - Component internal failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 68647 km
Date: 2018.09.22
Time: 09:28:56
Voltage terminal 30: 12.2 V
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730202C2823A017F1E06000000
Shop #: WSC 00066 790 00323
ASAM Dataset: EV_OCULowMQB 001003
ROD: EV_OCULowMQB.rod
VCID: 43D34CA8DB1FE38F2C6-8016
1 Fault Found:
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Bordcomputer-Setup (0x0F) - BapErr_RetryNotSuccessful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 68684 km
Date: 2018.09.22
Time: 16:11:26
End----(Elapsed Time: 01:32, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
www.Ross-Tech.com
Coding: 0E4DDD
Coding: 90A8DD
Sun Roof:
Coding: 191800
Roof Blind:
Coding: 191800
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 204
Mileage: 63852 km
Date: 2018.06.04
Time: 19:02:09
Alternator:
Coding: 30FFFF
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 177
Mileage: 68207 km
Date: 2018.09.03
Time: 11:17:11
Terminal 15: OFF
Coding: 011000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 68874 km
Date: 2018.09.25
Time: 18:53:58
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 68647 km
Date: 2018.09.22
Time: 09:28:56
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 68684 km
Date: 2018.09.22
Time: 16:11:26
