jcrews
Based on the conditions leading up to and following a deviation, it looks like the N108 advance solenoid is occasionally sticking. The advance mechanism itself looks OK, because the log indicates the mechanism is seeing the wrong pressure rather than getting jammed for a moment.
Mark 1: want 10.3 deg, got 1.1 CSV 35% @ 4053 : black smoke/ power drop expected
Mark 4/5/6: got 28 deg! (want 9.5-11) @ 2800: Power loss/ increased noise expected
Mark 8: a few degrees late in a couple of spots, but not as bad as above. May not be noticable.
Mark 9: 8 degrees late, similar to 1.
Mark 10: 3-5 degrees late, not as bad.
11/12: Nothing interesting
I'd like to see the N108 if you remove this injection pump.
