First start after new cam & balance shaft delete
Head887
Kentucky
Passat 2005
So I’m almost at the point where I’m ready to start the motor after doing my cam and balance shaft delete. Do I need to prime the oil pump / system? I did use assembly lube while putting cam in, it has been about 5 months since the rebuild of that makes any difference? If so how do I go about priming? I have searched but not much luck finding anything.
Is there anything else I need to do before the fierst start up?
Thanks for any advice!
Windex
Cambridge
05 B5V 01E FRF
By your title it sounds like you deleted your cam....
Please clarify, you deleted the balance shaft, as well as replaced the camshaft, 5 months ago and the engine sat un-started from then until now?
Head887
Kentucky
Passat 2005
Sorry for the confusion, yes that is correct. I installed a new cam and also deleted the balance shaft. Motor has now been sitting for about 5 months.
Mozambiquer
Versailles Missouri
1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI
Here's a thread that talks about breaking in the cam. If you don't do that, it can cause your new cam to wear out faster.
Windex
Cambridge
05 B5V 01E FRF
Additionally, it would be a good idea to crank the engine over with the glowplugs out and the fuel harness disconnected to build oil pressure prior to start
QuickTD
SW Ontario
2003 Audi A4Q 5spd 2.0 TDI 2056VK R783, 2006 Audi A4Q 6spd 2.0 TDI, 2007 A4Q 6spd 2.0 TDI
Start it, quick check for leaks, drive it.
dtrvler
Las Vegas
2006 Jetta TDI 5 spd
I always do this too...with clean fresh oil and filter to....get fresh clean oil everywhere...under pressure. I crank every engine without starting it...that i build no matter what type it is to run oil through it....but im especially concerned about getting oil flowing through the turbo before starting. It may not be absolutely necessary but im pretty sure its not hurting anything
