BarryT82
I haven’t connected it yet. I’m going to contact them to see if it needs changed.
I don't have many complaints about the fix on my Touareg, other than the way it holds onto gears like it's in sport mode when warming up. It's annoying when driving through town. Once it's warm everything is good, but I find myself putting it in manual mode if I'm driving around town and upshifting so it doesn't hold at 2500 rpm.The Q5 is supposed to go down by 1 mpg, so I'm not surprised the Q7 goes down a bit more. The car is programmed to run at higher rpm when cold to get emissions components up to operating temps more quickly. Higher rpms would be expected to result in more fuel consumption. My Q5 has not been modified and in D mode it certainly runs at low rpms. It'll be interesting to see the rpms post mods. Interestingly, the 2016 Q5s are predicted to use less DEF after the mods.
Frank, to mollify those who say that the Touareg's MFD (display) cannot be relied upon to determine whether the vehicle's MPG has dropped, would you be willing to hand-calculate your post-fix mileage, either on your current tank or the next?
Compared to what before the "fix"?1st tank - 515.5 miles/22.754 gallons= 22.6 mpg
2nd tank- 532.7 miles/22.011 gallons = 24.2 mpg
3rd tank - 497.5 miles/21.619 gallons= 23.0 mpg
That's in line with mine unfixed 2014 Q5. Going for the fix in about an hour. Will report back.Just finished the first tank of the fixed 2014 Q5.
576.6 miles. 19.295 gallons. 29.88mpg. 60/40 highway/local.
Don’t know about the pre-fix number.
+110% on that. Too many reports of fornicated up engines, especially among Audis, after the "fix".I have a 2015 Q5 TDI and, quite frankly, I'm afraid to let Audi (VW) touch my car.![]()
#MeTooQ5???+110% on that. Too many reports of fornicated up engines, especially among Audis, after the "fix".
What are you using the F350 for?2014 Q5 TDI Prestige S-line.
Had the fix done Thursday 1/25/18
The Good
1. Warms up much faster
2. Transmission shifts smoothly.
The Bad
1. Stays in lower gears until completely warmed up, and even then sometimes I can't use the paddle shifters. I have the gear selection enabled in the display so I know what gear it is in. Stays in 7th gear on my 8 mile trip on the freeway at 60 to 65. Maybe that will change when the weather warms up.
2. I have made this trip 5 days a week since the car was new. Always the computer would read about 33 MPG average once I get to work. Now it is 29. So it looks like I lost 1 mile per gallon off of the EPA rating PLUS the extra 3 to 4 miles per gallon that I am used to.
The only reason I had this done now is that I was at 50,000 miles and the warranty was about to end, and of course the $8800 from Volkswagen and the $1500 from Bosch.
I have a new F350 Super Duty 4X4 6.7 Power Stroke diesel pickup ordered. I was planning on keeping the Q5, as I don't want to use that as a daily driver. But now I think I'll trade it in.
I would recheck after you filled it again, full on the gauge may not be the same routine you use to fill it... We bought a Sprinter Itasca Navion. The PO filled it for us but I hand calculated about 10mpg, after my fills I get 13 pretty routinely with a heavy foot and every trip involves returning to Flagstaff at 7000'. I get 16 leaving town!1. 2014 Touareg TDI Exec 27K miles. Dropped off on Friday at 9 AM and returned repaired at 3 PM the same day. Vehicle fueled and washed and a multi point inspection completed. Nothing adverse noted upon pick up. Wife drove it 120 miles home at 73ish MPH on the interstate. Roads were wet and it was raining the whole way, no abnormalities noted. I topped the tank back up and recorded 23.7 MPG. The vehicle may have been filled prior to the repair and not certain if there was idling involved. this vehicle had averaged 27.3 MPG over the last 6K miles with a best tank of 31.2 MPG.
Have you seen Chevy is coming out with a Silverado 1500 Duramax? I am looking forward to that one...I am actually debating getting a Chevrolet Colorado with a Duramax Diesel
Did not realize that. Ford F150 will have a diesel too by August for the 2019 model.Have you seen Chevy is coming out with a Silverado 1500 Duramax? I am looking forward to that one...
Going to get a 5th wheel trailer and prepare for retirement in about a year or so. Plus I really miss not having a truck anymore. Should be here in about 5 weeks, so I have plenty of time to see if I can get used to the fixed Q5.Guy I work with bought the Colorado Duramax when it first came out. He likes itWhat are you using the F350 for?
I am actually debating getting a Chevrolet Colorado with a Duramax Diesel or a "new" 2016 Q5 TDI. My car has over 70,000 miles, so I want something with less miles for my daily drive. I am leaning towards staying in the Q5. I want/need the pickup truck functionality about 5 weekends per year, whereas I like the Q5 drive on my daily 35 mile commute each way.
I pulled the trigger on buying a 2016 Q5 TDI with 0 miles.Going to get a 5th wheel trailer and prepare for retirement in about a year or so. Plus I really miss not having a truck anymore. Should be here in about 5 weeks, so I have plenty of time to see if I can get used to the fixed Q5.Guy I work with bought the Colorado Duramax when it first came out. He likes it
There is noticeable louder engine noise during warming up.Thanks MBQ. Your mileage sounds optimistic . . . any noticeable difference in performance? Engine noise? Etc?
On point 2. I also have a A8L with the same CEL issue: glow plug. Service manager Text messaged me today that they'll most likely remove the cylinder head to see what is going on and Audi is heavily involved in this.1. 2014 Touareg TDI Exec 27K miles. Dropped off on Friday at 9 AM and returned repaired at 3 PM the same day. Vehicle fueled and washed and a multi point inspection completed. Nothing adverse noted upon pick up. Wife drove it 120 miles home at 73ish MPH on the interstate. Roads were wet and it was raining the whole way, no abnormalities noted. I topped the tank back up and recorded 23.7 MPG. The vehicle may have been filled prior to the repair and not certain if there was idling involved. this vehicle had averaged 27.3 MPG over the last 6K miles with a best tank of 31.2 MPG.
2. 2014 Q5 Prestige, 58K miles. Dropped off on Friday at 9:15 AM with a CEL that had previously been diagnosed as HPFP related. I was told to change fuel filter to clear CEL. SO when I dropped it off I provided them a new filter. Filter changed and CEL cleared. At 6 PM service guy comes to offer good news/bad news. Bad news is that the vehicle threw a glow plug warning light after repair and Audi wouldn't release it. Good news is that he has a 2018 Q7 waiting for me in the bay.
Still no word.
I am not disputing your statements. I have none of these issues. I was pleasantly surprised that my mpg readout on my commute home fir (35 miles of averaging 65-70 mph) showed mpgs of 32. y computer is not a lie-o-meter as some call it--it is generally only 1-2 mpg on the optimistic side.There is noticeable louder engine noise during warming up.
The transmission map was obviously changed but the fuel peddle is still tight at least. Performance is not changed significantly to the extent of unacceptable, I'd say. The engine runs at greater RPMs(maybe 1k more) all the time.
Do you have a loaner, has there been any discussion on possible remedies if they can't repair it? This is a vehicle that I have chosen to sell and have an approved cash buyer. I'm not happy.On point 2. I also have a A8L with the same CEL issue: glow plug. Service manager Text messaged me today that they'll most likely remove the cylinder head to see what is going on and Audi is heavily involved in this.
The car has been in the shop for over a month. First it was the dangerous broken floating bolt issue which waited for a long time for the brake caliper to arrive from Germany; second the emission fix; now it throws a CEL of glow plug issue.
Things are a lot slower than I expected/wished.
My service manager would have given me a loaner if I asked. I have the other fixed A8L with a CEL in my hand.Do you have a loaner, has there been any discussion on possible remedies if they can't repair it? This is a vehicle that I have chosen to sell and have an approved cash buyer. I'm not happy.
I have asked the service Manager to provide emails when he communicates with me so I have a verifiable timeline. To me, since these vehicles are under an extended warranty and they won't release them they should be eligible for Lemon law.
Maybe a new thread for folks with affected vehicles?
