vwestlife said:
Quoth VW specs for the 2003 TDI:
VW Mediaroom: 2003 Golf
"OBD D, Tier I, catalytic converter, water-cooled EGR system, onboard refueling vapor recovery (ORVR)"
Yeah, and that is clearly wrong since diesels do not have EVAP systems like gassers
Go ahead and check any TDI for an evap monitor
Still don't. Diesel does not evaporate like gasoline does. That's why diesel pumps do not have the little "foreskin" on them.
SAE sets the OBD standards, and if you look in VESIS, Bentley, Alldata, Erwin, or any other official manufacturer publication you will see the OBD2 status. You can read all the OBD2 standards and protocols on SAE's website, I forget the exact link. The US EPA is also a big contributor to these protocols, and TDIMeister could better explain all that stuff.
It is really just a matter of semantics, since it really has no bearing on how the system really works other than DTC and component nomenclature, as well as DLC location, CAN/comm protocols, etc. That is why the early OBD-D B4 has some funky differences in its engine management system, as it was not up to the full OBD2 mandate yet.
"OBD" was mandated by the US EPA starting with the '93 model year new light duty vehicles. There was a phase in allowance for some manufacturers for some items. This was why all the carburetted Japanese trucks went away from our shores around that time. The "OBD2" was originally a CARB mandate, but was adopted by the US EPA for model years starting 1996, however again some allowances were made (like the early B4s).
The next big mandate is the CAN communication protocol, which the Germans have had for a long time (CAN is a Bosch term). CAN mandate comes in 2008 or '09, not sure. Most vehicles already have it. Most VAG products sold here got it in 2004. EDC16 does not play nicely with the old "dumbed down" system Volkswagen used, so all US-spec PD cars are CAN.
Here is some basic OBD2 info here:
http://www.obdii.com/background.html
Notice the "January 1, 1996" date. And if you look under the hood of any '97 or newer TDI you will see the words "OBD II certified"
However find an early '96 B4 and you WILL see the "OBD-D certified" in place.
