JonnyObnoxious
Balance shaft delete and ~245,000 miles.
I got most of these identified, but there's a couple I can't find. I'd also like confirmation that I am chasing the right things.
Engine:
16485 P0101 Mass or Volume Air Flow Circ Range/Performance
16486 P0102 Mass or Volume Air Flow Circ Low Input
16512 P0128 Coolant Thermostat/Valve Temperature below control range
16786 P0402 Exhaust Gas Recirc.Flow Excessive Detected
17058 p0674 cylinder 4 glow plug circuit intermittent
17978 P1570 Contr.Module Locked
19557 ?
19558/P3102/012546 - Motor for Intake Manifold Flap (V157): No Signal
So it looks like I nee a new MAF; it's been flaky so no surprise. Probably a thermostat? Also no surprise since mine seems stuck open. Inspect and service the EGR system. Glow plug on #4: tune up time? 17978 doesn't seem to be a real thing since it starts right up. Somehow related to salvaged CCM? Intake manifold flap?
Transmission:
17100/P0716/001814 - Transmission Input Speed Sensor (G182): Implausible Signal
17125/P0741/001857 - Torque Converter Clutch: Stuck OFF / No Power being transferred
18258/P1850 - Powertrain Data Bus: Missing Message from ECU
Looks like a TC failure, better than a transmission failure. Jeff called that one. What's this speed input sensor and data bus issue?
SRS
00532 - Supply Voltage B+: Signal too Low
00591 - Seat Belt Switch; Driver (E24): Resistance too High
00592 - Seat Belt Switch; Passenger (E25): Resistance too High
01217 - driver airbag fault
01218 - passenger airbag fault
Replace my failed battery. New seat belt switches? The airbag faults are from running it without the seats in.
ABS:
01423 - Lateral Acceleration Sensor (G200): No or Incorrect Basic Setting / Adaptation
01424 ?
WHAT ARE THESE?!?
Thanks in advance for helping to identify these issues for either me or the next owner.
Engine:
19557 ?
Transmission:
SRS
ABS:
01424 ?
WHAT ARE THESE?!?
