Finally just got vag-com. What should I check first?
naspet
romania
Skoda octavia combi 2 1,6td1\i
Help please
If i activate a service regeneration(with vcds interface) the engine is working normaly not limp mode (warning light are still on) .
How can i reset tis errors and after that to try again a service regeneration .
It is posible that this isues be caused by egr ???
i use a vcds interface to scan for error codes and here is a part of log file
FOR Engine
ddress 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LP HW: 03L 906 023 JH
Component: 1,6l R4 CR td H43 8810
Revision: --H43--- Serial number:
Coding: 00114016032400080000
Shop #: WSC 30924 001 1048576
ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
ROD: EV_ECM16TDI02103L906023LP.rod
VCID: 7F0A9BD3E6EEDBC624-802A
1 Fault Found:
16848 - Diesel Particulate Filter
P2458 00 [175] - Regeneration Duration
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 175084 km
Date: 2017.01.26
Time: 09:50:19
Readiness: 0000 0000
And here some mesurments of EGR
016 Actuator for high pressure EGR; status-LF_STATE_EGRV_DISP[0] 6
073 EGR Vacuum Regulator Solenoid Valve; activation-ANG_SP_EGRV[0] 0.000 %
074 EGR valve; offset closed-V_EGRV_BOL[0] 0.928 V
075 EGR valve; offset open-V_EGRV_TOL[0] 3.999 V
129 Exhaust flap; actual value-ANG_EGRV[0] 0.000 %
130 Exhaust gas recirculation (EGR) cooler pump; specified value-PWM_EGRCP[0] 95.001 %
156 High press EGR actuator; actual unconditioned volt val-V_EGRV[0] 0.928 V
160 High pressure EGR actuator; activation-PWM_HBR_EGRV[0] -15.436 %
384 EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG 0.000 %
385 EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG 0.000 %
386 EGR_deviation-EGR_DIF 0.000 %
Ol'Rattler
PNA
2006 BRM Jetta
I did a few things. Drl down to 35 percent. Was going to disable, but carrying kids I kept them on, and they are killed while blinker active.
Running your DRL's at 35% will burn out your bulbs a lot quicker.
They do nothing for safety and are not mandated in any of the 50 states. If I want the lights on the front of the car on, I reach down to the switch and turn them on. My Euro-Switch has 3 positions all lights off, parking lights on and all lights on.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
DRLs make your car easier to see by pedestrians. I've replaced my headlights once since 1999.
jason_
grand rapids michigan
2015 s wagon dsg
I actually went to 15,% since then.
Factory was 98%.
Sent from my S-Off'ed HTC One...
Rob_MacCara
Halifax, NS
Audi Q3 gasser
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
You'd get a ticket if you were visiting here and had your lights turned off.
http://novascotia.ca/tran/roadsafety/daytimelights.asp
This is why when I installed my Euro switch on my MkIV, I did not
delete the DRLs. I frequent the 1000 Islands.
Switch off, DRLs are stock, ie., on, and Canadian legal.
Position 2; Parking/City Light setting, my blue LED front parking bulbs come on, AND the rear lights,
(I actually think this is a safer setting than the headlights alone), no headlights.
Position 3; headlights and parking lights on.
My feeling is the blue light parkers are very noticeable, being associated with "police activity". Legal, at least here in PA.
I want to be seen!
