thelemite
Driver: thelemite
Miles: 554.1
Gallons: 13.170
Model Year: 2009
Model: Jetta Sedan
Tranny: 6M
Fuel Type: ULSD
Miles: 554.1
Gallons: 13.170
Model Year: 2009
Model: Jetta Sedan
Tranny: 6M
Fuel Type: ULSD
Don't I feel special,the only one with an01M and I'm in the middle!scooperhsd said:FEBRUARY 2009 Mileage Thread
This is a month by month competition. Every time you make an entry it will be added up and recorded together according to the fuel type and car/year you are driving.
THIS IS NOT an individual tank competition (or a partial tank competition for that matter).
Entries will be accepted until MARCH 5th 2009, but remember, report tanks FILLED IN FEBRUARY.
Entry Format:
Driver:
Miles:
Gallons:
Model Year:
Model:
Tranny:
Fuel Type:
You are allowed to put more than one fill up in a post, so long as each fill up conforms to format.
MPG: (optional since I will calculate it automatically anyway)
(anything else you would like to add)
Hint on entering your data - after the colon ( ":") put a space.
US GALLONS AND MILES
TRANNY TYPES:
(x) A = x speed automatic
(x) M = x speed manual *
DSG = direct-shift gearbox
CVT = continuously variable transmission
* if you have swapped in a taller 5th gear please noted this (ie: 5M w/.681)
FUEL TYPES:
Bx = biodiesel - x is the percentage of bio
Biodiesel use equal to, or more than B20, will be indicated in GREEN.
ULSD / LSD / D2 = normal petroleum based diesel
Also please note if it's winterized
- please note if you are using a fuel additive (ie: ULSD +PS)
- - Power Service (PS); Stanadyne (ST); Redline (RL)
Posts not in format will not be tallied / corrected. If I have to do any editing to get your post in format (or to get the correct name), it will not be counted. Feel free to correct your own posts to get them in format.
Please do not go back and add additional fillups to a post. Multiple fillups per post is fine as long as all fillups are in format. If the driver name is not the same as your post name - this will be considered "Not in format" and will not be counted. Only exceptions would be "and spouse" etc.
That's because "01M" is the wrong formatJASONP said:Don't I feel special,the only one with an01M and I'm in the middle!
So does that make me a returd?Bob_Fout said:That's because "01M" is the wrong format. There are others with the correct "4A" nomenclature in this situation.
Most TDIs with worse MPG than you are MK Vs too.
Of course notJASONP said:So does that make me a returd?![]()
