tditom
- Joined
- Sep 5, 2001
- Location
- Jackson, MI
- TDI
- formerly: 2001 Golf GL, '97 Passat (RIP) '98 NB, '05 B5 sedan
remember that many of the CR owners are n00bs
Funny you mention it. I'm having a hard time comprehending your insuation, but anyways.tditom said:lol- reading comprehension, anyone? I guess you are NOT an anti-507 guy. so why are you answering??
and why do you edit nearly every single post you make?
You spelled insinuation wrong. You should edit your post.Elfnmagic said:Funny you mention it. I'm having a hard time comprehending your insuation, but anyways.
I edit my posts because I usually find a spelling error or 3. Bother you?
not usually (i mean i don't usually bother- not that i don't usually have spelling or grammar errors )Elfnmagik said:...
See what I mean? I'm always in a rush and am a terrible typist. Anyways, time for some juice.VeeDubTDI said:You spelled insinuation wrong. You should edit your post.
(sorry, couldn't resist)
Bob, thanks for the links to at least two more ACEA A3 oils you can use in a CBEA engine !. So you see the "consequences" are straight out of the 2009 TDI VW owners manual (sedan) Again an oil that meets the ACEA A3 specification . (5w30 preferred)Bob_Fout said:http://www.tdiparts.com/catalog/product_info.php?products_id=479
http://www.redlineoil.com/product.aspx?pid=2&pcid=21
Most of the 5w30 505.01 oils are also ACEA A3.
The answers or lack there of, to questions like these are the real points or reasons in Bob Fout's msg 69. Indeed the Delvac One 5w40 was/still NOT VW (505.00@ that time) certified, but met/still meets a FAR higher standard. However as you can see by his picture of the sourced document, you would NOT get that reading the VW owners manual. Further research would be in order to know that, let alone come to that conclusion and make the switch from VW 505.00.DPM said:Rod, where's the ACEA C- rating for that oil? What are the differences between (say) ACEA C3 and E7?
pre-PD engines did not require a VW spec oil. The API CF-4 spec was fine. So Delvac1 did not need to meet that spec to be approved for tdi's. Therefore it was OK'd by VW for use in the tdi engine. I don't see how anyone could come to any other conclusion by reading the manualruking said:...Delvac One 5w40 was/still NOT VW 505.00 certified, but met/still meets a FAR higher standard. However as you can see by his picture of the sourced document, you would NEVER get that reading the VW owners manual...
While you seem to agree with my choice of Delvac One 5w40 over the years, it would be hard to come to that conclusion: 1. @ that time 2. when there was no PD engine on the market. So your argument is strictly arm chair 2nd string quarter backing.tditom said:pre-PD engines did not require a VW spec oil. The API CF-4 spec was fine. So Delvac1 did not need to meet that spec to be approved for tdi's. Therefore it was OK'd by VW for use in the tdi engine. I don't see how anyone could come to any other conclusion by reading the manual
When the PD engine came on the scene, VW no longer OK'd the use of API spec oils. This applies to the CR engine as well. This is not to say that some oils won't work just fine, but you're screwed if you try to get VW to back their warranty if you've been using "non-spec" oil
all your other babbling aside, i have used the following oils in my MY01 ALH:ruking said:.... Did you use Delvac One 5w40 for your 2001 back then?....
A little touchy are you, especially when you are the one babbling?tditom said:all your other babbling aside, i have used the following oils in my MY01 ALH:
VW505.00 (various makes and weights)
VW505.01 Elf 5W30
Delvac1
TDT
Rotella T 5W40
Well for sure I wish you at least another 240,000 miles !! I am shooting for 500,000 miles minimum also. Let's see so far in 120,000 miles I have done 6 oil changes.tditom said:over 240K miles i've had lots of oil changes and have used whatever was on sale or easiest to get.
Back to the subject of this thread- there has not been enough data collected to determine if one VW507 oil is "better" than another. keep it simple and stick to the spec. Don't let the PD cam problems scare you into voiding your warranty
If you are asking me... no.Bob_Fout said:Does your owner's manual mention the half-liter/ top-off only qualifier that BTL's does?
correct me if I'm wrong, but all VW507 is 5W30. I would assume that an oil that meets VW507 would also meet ACEA A3. So I'm not telling a CR owner to disregard what the manual says.ruking said:...Problem is the 507.00 is 7.50 to 10 per liter so the issues are a little more picky picky.
To stay on the main point/principle, this is essentially what was done with Delvack 5w40 et al. back in 2003.
So I take it you want to totally ignore the owners manuals recommendation of ACEA A3 5w30.???
tditom said:correct me if I'm wrong, but all VW507 is 5W30. I would assume that an oil that meets VW507 would also meet ACEA A3. So I'm not telling a CR owner to disregard what the manual says.
oil change interval is 10K miles. You have enough time to shop for the best deal. What is the difference in price between 507 and Delvac1? The best I've seen for D1 is $27/gallon. From what i've heard, Pepboys is selling the 507 Mobil1 product for the same as the other M1 oils (~$7/L). For that miniscule difference in price, why risk the warranty or potential long term issues?
no one has ever proven that 505.01 oils have caused a PD cam to fail, or that any other oil would save a PD cam from failing.
