Pugs's MAF was crapped out, and Sprockets' is close behind. In fact, Pugs's Bora is running on Evil Beetle power right now until he can get a new one. We swapped in my MAF yesterday to see if that was causing his severe lack of power and boost. Sure enough, it was. He kept getting an error code, but it had nothing to do with the MAF. The code said, basically, that the manifold pressure wasn't as high as the ECU expected to see. It was some kind of "boost control" error, or something. Apparently, the ECU doesn't recognize the problem as being related to the MAF unless there is no signal at all. Pugs was still getting a signal from the MAF, but it was a lot weaker than it should have been.
-mickey
