detroitmike
So I did a scan w/ VCDS and came up with 2 fault codes. I was really trying to avoid the dealer for anything even though I am still under warranty.
Maybe someone could tell me what these are and if I should really get them checked by the dealer or just clear them. The car seems to be running fine.
2013 Passat TDI
8468 Miles
Exactly what the distribution flap does seems obvious enough and I never noticed a problem switching from vent to defrost etc. but the NOx sensor I'm not too sure about. Emissions obviously but is this code telling me the sensor is bad and I need it replaced?
Any advice appreciated.
Thanks.
Address 01: Engine (J623-CKRA) Labels: None
Part No SW: 03L 906 012 BN HW: 03L 907 309 S
Component: R4 2,0L EDC H23 4804
Revision: 71H23--- Serial number:
Coding: 001D0012042400000000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012BN 004007
ROD: EV_ECM20TDI01103L906012BN.rod
VCID: 71C70FC4A0027D90DE2
1 Fault Found:
18648 - NOx Sensor 1 Bank 1
P2201 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0 0 0 0 0
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 561 907 426 A HW: 561 907 426 A
Component: AC Manuell H02 0101
Revision: 00001K06
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC.rod
VCID: 191717641832D5D0C62
1 Fault Found:
9477489 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 11642 km
Date: 2006.14.12
Time: 21:21:34
2013 Passat TDI
8468 Miles
Thanks.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: 00001K06
Coding: 0010001002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 11642 km
Date: 2006.14.12
Time: 21:21:34
