l_c
Turn Signal gets STUCK ON, after using Key (or Remote) to Lock or Unlock doors!
This issue has been Identified and Resolved (Fixed) (11-Apr-2008), read through to latest post. Also rewriting / cleaning up this first post ...
UPDATE, Feb 2016: See THIS POST for an overview of approaches that might be taken
(Adding) Background Information:
On this (ALH / 2002) model, the Right and Left turn signals each have an Indicator on the driver's Instrument Panel (i.e. in the dash "cluster" aka the IP); each of those lights also connects with exterior lights (Front, Side, and Rear of vehicle), one set each (Right and Left).
When the driver uses the Turn Signal (Stalk Switch, i.e. the switch which is on the Steering column), the turn signals are driven (switched On and Off) by a relay module which is located at (the rear portion of) the Hazard Light switch. It is possible to have problems arise from either the Turn Signal Stalk Switch, or from the Hazard / Turn Signal Relay. (More likely the stalk switch ... subject of several other forum posts.)
The subject of this forum thread however is that — The Turn (Signal and Indicator) lights are also driven (switched On and Off) by another source ... the Central Control Module for Comfort System (aka the Comfort CCM). If you look at the A4/ALH Wiring Diagrams, in the Comfort System wiring diagram, on the page having title "Central control module for comfort system, antitheft warning system, antenna wire for central locking and antitheft warning system", this driving connection can be seen as pins 13 and 14 of the CCM drive wire nos. 2 and 18 of the IP control module, and also drive nodes A5 and A6 (which are the Turn Signal Lights). The official VW/Bentley wiring diagram does not, however, show us anything about what is inside the CCM itself, at these two terminals. It so happens that the Turn Signal Lights/Indicators are driven by a 5-terminal, twin-contact 12V relay.
When you use either the Key, or the Remote Control (fob) to either lock/arm or unlock/disarm the locking/alarm system, the CCM blinks all of the turn signal and side marker/indicator lights, as acknowledgment. But if the blinking action by the CCM does not finish (return to low-potential) properly, those lights will remain fixed in the "On" (burning) position, which is a terrible situation (current drain, melting lenses, burning the bulb filaments. If you happen to notice it occur, you can repeat the lock or unlock, several times, until it finally switches off. In my case, as this problem got worse, it would eventually require up to 10 or more repetitions until the light circuit would successfully turn "off". On my vehicle, one contact (or "pole") in the CCM twin-contact output relay has been tending to become stuck "on", when the ambient temperature is warm (or, when the vehicle isn't cold), thus making the driver's-side lights remain stuck lit (on). Never when actually using the turn signals; only by CCM lock/unlock. By the way, when it gets "stuck", you cannot use the turn signal of that direction (right/left), since the node is driven high by the CCM relay.
Check below (to the final post) to see how I finally resolved/repaired the issue. Thanks; Larry C.
__________________________________________________________
(Apr 2007) I've seen references (on TDIClub and/or VWVortex) a couple of times about this issue; have now spent hours trying to retrieve a post, and can't seem to find it --
On occasion, I lock (arm) the Jetta Wagon (2002 ALH) using the remote, neglect to look closely enough at the car, then later on when I return to the vehicle I find that the left (driver's) side marker lights / turn signal indicators are stuck on (lit), and feel a bit hot.
If I unlock/disarm using the remote, then they go back to normal. In all other respects, this vehicle locks/unlocks/arms/disarms without a problem. I replaced my front door lock modules a couple of years back (due to microswitch issues), and have also done the turn signal stalk switch (and flasher module) about 3 years ago. (All three lights remain lit -- front, side, rear.) (It would not likely be a brake light switch issue, I believe.)
So, I would search for "stuck on", "stays lit", "one side", whatever. For some reason, I can't seem to locate any topics relating to this issue now. Sorry to open a new topic but, does anyone know about this issue, and would it be a relay module, or else something in ECM/CCM (I doubt it)? Thanks; Larry.
p.s. JeffBrom asked the same basic question in the 101 forum here
