My 2011 golf TDI has a fan issue. I can hear it kick on when when i am driving and it don't shut off when the switch is turned off. The car shows its running normal on temperature. Is cold out so they should be running anyway. When i shut it off and the fans are still running i start it back up and it sounds like they shut off. I turn the key back off and they are off for a second then it sounds like they come back on low. I do this several times and they finally stay off. This is my first MK6 so i got a few ideas but not many. I was going to check the connection on the coolant temperature sensor, the connection to the fan. I have read that an issue with the big fan can cause this. I thought about looking with my vcds and seeing what the temp is reading(just need to find what to look at) Just haven't had with me when problem happened. It done it once and was good for several drives and the last two times i drove it has happened again. I just got this car so i have no history with it. If anyone else has any input or advice i will gladly take it.
Thanks,
Musky48
Thanks,
Musky48
