Escape.idiocracy
Searching has shown me a lot of posts on catch cans are bad for cold environments… not a lot on any actual benefit. Searching failed PCV valve hasn’t given me much either…
I am getting a bunch of oil being pushed through the CCV and seeping from the turbo muffler pipe area.
I have checked the turbo shaft- it’s fine. (Thought maybe the turbo went….)
Car is at 55k miles
(2014 2.0 Cjaa sportwagen)
Any thoughts, ideas, ? Pretty mechanically enclosed and doesn’t seem to be anything obvious.
Edit
Found a diagram of “CCV” :| valve cover assembly….. $300…
Anyone know of a good way to “check” the CCV to see if the little check valve is maybe stuck/gummed up? (Slightly frustrated- always used 507 oil even when Not needed and changed every 5-7k miles- so for it to potentially be “gummed” up with this few of miles.)
Car is at 55k miles
Edit
