roni024
Does anyone know if there's a list someplace of all the warranties VW extended for the NMS Passat? I know that not all VINs were included in each extension, but I'm interested to see what MAY have been extended for my car.
Wow. You have put some miles on that car. Trouble is, you're only 200 miles from the end of all three extended warranties I have (turbo, AdBlue heater,and heater core, the latter being replaced Thursday). If nothing's s wrong now,you have no basis for warranty service, and if you drive it a few hundred miles, you're over the warranty. A lose-lose scenario....Thanks for the advice. I'm at 119,800 miles now, so trying to get any needed service done before warranties expire would be prudent.
This is good advice. My dealer replaced my heater core when I was able to prove the passenger side heat didn't equal the driver's side....If your heat is less than adequate or cooler on the passenger's side than the driver's side, inquire about getting your heater core replaced and the coolant flushed prior to the 120,000 miles deadline.
This seems to be a weird issue where some VINs in the same model year have the warranty, and some don't. Don't ask me why. Our '13 Passat TDI SEL has the extended warranty, as it does on the turbocharger and the DEF heater, and our heater core, which had started to go cold on the passenger side, was replaced at the dealer today, heater core, gaskets, flush, and coolant, todo incluiso at a cost of $0.The dealer called me to tell me the heater core is not warrantied. They called VW to ask for a goodwill repair, but VW denied it due to the high mileage. Repair cost will be over $700 should I decide to fix it.
Are you all sure about the heater core being warrantied until 120k?
