I am running stock size for 2 years and 20k km, all OK.No one else has ran these Wuzetem nozzles eh?
I will test 0,260 from wuzetem soon.
since my last post ITT I've swapped out the DSS-r .360s
found some $7 chinese garbage ".30" nozzles and they are actually working out better in every way than the DSS ones, mind you I bought a hundred bucks' worth and chose the best from the lot
the spray pattern was horrible, sputtering out streams from a few of the holes no matter how hard I pumped the pop testerWhat did you not like about the dss-r .360 nozzles ? I'm might be stuck pushing 500+hp worth of fuel through a .360 nozzle using a 13mm P3000 plunger.I see that ebay has cheap .360's,Gibonta and DSS-r have .360's too.I've talked with Gibonta and researched the Cummins 5.9 stuff and figure that a .360 should be big enough for my goals and provide better atomization.I've ran 5x.017" 5.9 (6bt) nozzles in the past however now want the correct "VE" nozzle orientation and spray angle.
spray angle is very important, I would check into getting vw nozzles edm honed before I got Cummins nozzles.the spray pattern was horrible, sputtering out streams from a few of the holes no matter how hard I pumped the pop tester
only one of the set of 4 that they sent me was even decent
I've actually been thinking about going the other direction and using the 7mm 12v nozzles just to get a quality nozzle in a larger size, even though the nozzle orientation in the head is (10 or 15 I forget) degrees off. Figured I'd get the 145 degree cone ones to make up a little of the difference.
I have the gibonta.460 in my golf from darkside. Sent the bodies to them for mounting and pop testing. If I ever finish the wiring on it I’ll post on how they do.
I'm running some aliexpress "oomyapoo .30mm" p502s with a de110/12mm pump and it is basically running clean at 45 psi from an he351w atop a td04hl5cm. Even with 15 psi of lift pump at the injection pump inlet.Dont waste your money on Gibonta, just go to AliExpress, type DSLA150P502 and you will find same Nozzles with DLC for much better price. In my project I use 0.330 Nozzles and get 380hp and still have little space for more fuel with them using rotary 11mm plunger.
You forgot to mention what turbo was used in that setup. For some gtb2260vk based hybrid it's very good result. Jukums has GT3067S and guys in Finland have S200V hybrids, S300V's or 2-stage turbos.congratulations,
I saw dyno of chinesse 0.370mm (250/350bar) + 107J pump (4500mV at N146) and it was 350HP.
