Fix_Until_Broke
I've been working on measuring Exhaust and Intake Manifold pressures on various cars and finally have a small compilation of data to report. This has been recently discussed in this thread Sounds like we need a kit for measuring EMP! and in this thread EMP as related to the VNT 17/22, but I thought I'd start a new thread with the results.
The data is taken with a combination of devices. Boring technical stuff follows
First is VagCom logs of fields 1, 3 & 11 which provides RPM, fuel requested and delivered, MAF requested and delivered, MAP requested and delivered, N75 duty cycle and coolant temp among the useful data. This information is sampled at a relatively slow rate (~0.4 seconds/2.5 Hz for RPM and ~1.16 seconds/0.86 Hz for everything else).
Second - the external pressure measurements for Exhaust manifold pressure, intake manifold pressure, Airbox pressure, etc are taken with 0-50 PSIG pressure sensors on 0.5-4.5Vdc signal so they have the ability to read a little over/under pressure. Accuracy is decent at +/- 0.25% best fit straight line combined linearity, hysteresis & repeatibility with a total error of +/- 1% of full scale (0.5 psi maximum error). They will withstand 2x over pressure (100 psi) without calibration shift, -40 to 250F operating temp. These sensors are read by a 10 bit A/D converter which gives 0.061035 psi resolution and samples at 0.01 seconds/100Hz on all channels. This is then broadcast over CAN and saved as a .csv file.
There is a switch that can be put on any of the sensors and shorts the signal to ground which effectively gives me a trigger. I will switch this from shorted to not at the same time that I click the Marker button at the beginning and the end of the block of data that I'm interested in. I go into each file and find these two points and align the data about these points. The gaps in the data are copied from the previous known data point which is why the VagCom data is "blocky". These two files are manually merged together so as to be as close to time synchronous as practical/possible. Depending on the response of VagCom markers this can be up to a second or more off, but for the most part it's close enough to get the idea.
I'll just post "pictures" of the data for now (I'll try and improve the quality of them in the future). If there is something else you'd like to see (I'm thinking of trying a plot vs RPM's instead of time?), so long as it's in the original data file(s) it's pretty easy to do. If anyone has interest in the raw data files, PM me with your E-mail address and I'll send them to you in varous stages of post processing. If anyone is a whiz with merging .csv files together with different sampling rates of different data and filling in the blanks, I'll take any help I can get. There's about 2 hours of work in merging each one of these pairs of data files to get them to the point where I can spend ~3 minutes generating the pictures you see.
Thus far the below data is taken during a 3rd gear run from ~1500 RPM, going to 100% throttle by ~1800 RPM and running it to ~redline. This is a balance of getting enough Vag data to make it worthwhile and keeping the speeds semi-safe (they're way beyond legal if we were to be on a public road). Suggestions are welcomed for future testing methods, things you want to see, see different etc.
I'm trying to get a variety of configurations logged. I didn't get as much done at the GTG as I hoped, but will try to continue to get additional data points. I'd currently like to get a stock 5 speed ALH tested as well as an A4 PD 5 speed, also stock. I'll try to attend regional GTG's if there are people willing to have this testing done on their car to contribue to the greater good. This will be an ongoing thing I hope, PM me if you're interested and we'll see we can coordinate something.
1) Fix Until Broke - 2003 Jetta ALH 5 Speed
a) VNT 17/22, 3" Downpipe 4" AeroTurbine XL muffler, 4" Exhaust, RC4, PP502's, 10MM Injection Pump, EGR Delete, 3 Bar MAP, PD Lift Pump, 3" Turbo Inlet Pipe, CC vent to Atmosphere, N75 vent to atmosphere, Stock Airbox/MAF/Intercooler/Intake Plumbing
2) Fix Until Broke - 2003 Jetta ALH 5 Speed
a) Same as #1 but with RC6, Keystone Mod and 2nd 4" muffler
3) Bob Fout - 2003 Jetta ALH 5 Speed
a) VNT 15, Sprint 520's, Gator Tune, Kerma Downpipe, 2-1/2" Magnaflow Cat, 2-1/2" Cat Back, Pierberg MAF, Stock everything else
4) Jason TDI - Jetta ALH 5 Speed
a) VNT 22/18, RC6, Stock Exhaust, FMIC, EGR Delete, Jason PM me with your mods so I can update this.
5) Love My Bug - 2002 Beetle Automatic
a) Stock (it has a boost pressure tap now)
b) I was having VagCom problems so no Vag data but have the pressures vs time
