dieB4sel
Recently the timing belt was changed on my car (113k miles)performed by one of our members (very cool to watch). He suggested I also replace the down pipe of the exhaust as it is likely congested.
On my car the down pipe appears to be an integrated unit from the manifold to the "catalyst"... while the Bently manual and the illustration received from IMPEXFAP.COM show it to be a two piece with flang bolt-on configuration.
My questions:
1. Rather than replacing this down-pipe/"catalyst" section, can it be taken off, cleaned out and then reattached?
2. If I must purchase a new down pipe, will the two-piece replacement parts be a straightforward job or is there usually some custom fitting involved? This also includes the funky fact that the 96 Passat had that 5th injector going into the down pipe (I blocked the 5th injector seveal years ago). I am not sure what to do with that injector fuel line... could it just be rolled up and moved out of the way?
3. If there is an option to replace just the down-pipe and have it welded on to the old "catalyst", is that reasonable... or is it likely that if the down-pipe is clogged that the "catalyst" may be constricted as well? With the cost of having that welded on, would I just be better off replacement that "catalyst" with the two-piece?
Thanks for your insights - dieB4sel
My questions:
