JaysinSpaceman
Hey guys,
I have to say that I am a bit concerned about asking this question after a search of the site and finding a lot of negative responses in regards to putting an exhaust brake on a stock car with a TDI, but I suppose maybe asking here in the swap/conversion area might be a better place for it. I will be swapping a TDI into a toyota pickup and I live in a very hilly area and could see an exhaust brake being beneficial. I am NOT talking about a Jacobs Brake. Simply a butterfly in the exhaust system that causes back pressure and slows the engine and therefor the vehicle. (Anyone with info on how exhaust brakes work on diesels feel free to correct me if I've got it wrong.) There seems to be a common problem on older Toyota pickups with warping front brake rotors even with a gasser that will supply some engine braking force and I figure that adding a diesel that doesn't, by it's very nature, supply any engine braking (save for a bit of internal friction/pumping losses) this problem might be increased. What would it take to install and exhaust brake on a TDI in a toyota? I know it would take a vacuum operated butterfly valve in the exhaust and you would have to limit back pressure to keep the engine's exhaust valves from blowing back open. Some way to switch the brake on and off, like a electric switch on the throttle so the brake engages when your foot is off the accelerator peddle or a switch on the brake peddle so that you just barely depress the brake peddle to actuate the exhaust brake. Is there something that I am missing here?
Calculating the back pressure that could be allowed should be easy enough, just need to find out the exhaust valve spring seat pressure and the area of the exhaust valve and you could calculate out how much PSI back pressure it would take to blow open the exhaust valve with stock valve springs. Then some sort of blow off valve or orifice in the butterfly to control back pressure keeping it below this limit.
It is just an Idea floating around in my head at this point, so try not to jump my S#!t to bad for it. I would think that those of us using these diesels in conversions might benefit from a technology that larger diesel pickups utilize to save their brakes etc...
Picture of exhaust brake.
Thanx,
Jaysin
Thanx,
Jaysin
