OK, first off, some background on this problem. As most of you know I had a 90hp ALH in my car to start with, then I blew it up, so I installed a 110 euro motor. This engine has been running for 15000 miles without a hitch using a ALH ECU with an upsolute chip for the most part. Several weeks ago, the car started acting up. I would start the car and it would die right away. No errors or check engine lights. It repeated this four or five times and then finally started. While driving down the road, the glow plug light started to flash, and the check engine light came on steady. I made it home and scanned the codes. Well 1 out of ten time I was able to communicate with the ECU (engine). I was able to bring up the airbag, brakes, instrument, and central convienance. WEIRD... So I finally get into the engine computer and find this DTC..
01039 - ECT Sensor (G2) Open or short to B+ - Intermittent
00562 - Fuel Consumption Indicator (Y10) Open or short to B+ - Intermittent
I clear those codes and go into the central convienance
I find... 01131 - Front Infrared Sensor (G166) Unknown Switch condition. This sounds like a sensor for the full alarm not even compatible with this central locking module.
So I'm confused. Now the car is acting up more than ever. I start it, drive 10 miles, shut it off and it won't restart. I decide to leave for the weekend and come to the conclusion this might be a Relay 109 problem, as the one I have was black and was extremely hot to the touch. I opened the case on it and the metal was discolored and smelled burnt. I called the dealers in grand rapids and lansing, as I was traveling down in that area, nothing till monday was the result.
On my trip (making sure not to shut off the car) I noticed much lag and turbo surge. Holding the accel pedal at the same spot caused lurches in acceleration, up to 80 down to 70, then the power would come back and I was at 80 again. Seemed like a boost valve was sticking or something. (BTW.. still haven't replaced a MAF sensor after 90000 miles on the car)
I call GEWILLI, stop by his place as he had a spare relay 109. I shut off the car, install the relay, and the car STILL won't start again. At this point, I'm extremely pissed with this stupid car, and geoff starts calling people for advice. We try talking to the ECU with my laptop and his, with both vwtool and vagcom, and absolutely NOTHING. We can't find out what the DTC's are stored inside. So now I'm stranded in lansing, with no running car. We mess with all sorts of [censored], unplugging batteries, reconnecting the plugs at the ECU, trying to start with a jumpered fuel solenoid, unhooking the coolant temp sensor... blah blah. Then for some reason the car started after it was all back together.
I'm on my way again, off to Toledo. I park the car at the hotel, shut it off, and try to restart.. NOTHING. Its dead again. I come back in two hours, it starts first try. I still cannot talk to it with vagcom at this point. I go to bed, wake up in the AM, go to the car, and it starts first try.
Now, it is extremely slow, and can barely make it to 70MPH on the freeway. I go to my friends house in ferndale (detroit) and stop the car. It doesn't start again. So I figure while I wait for it to cool down, I'll switch the EGR valve which is not in use with the N75 Boost valve. I get it back together, and the car starts. Drive it down the street and I have NO power below 3500, thgen it hits harder than EVER before. It pulls to 5000RPM , and boost comes on at 3500, no less. Its a turboless dog below 3500. I go back to his house, shut it off, and ride his motorcycle around a bit. 30 minutes after shutting off the car, try to restart to leave and no dice. It takes 12 cranks to get it to run at more than an idle and then shutting off. I'm on my way once again.
Now I'm driving to Grand Rapids again to drop a friend off. We are flyiung down 96, I mean, the casr is running AWESOME at 70+ speeds. it pulls to redline in 5th faster than ever before. So, I still have to figure out low rpm boost, but I'll take care of that when I get home. The car does not surge anymore, and holds speed better than it has in a long time. Its running better in warmer weather than I ever remember.
I'm about 50 mles from home, when all of a sudden, NO POWER. I can't hold 55. I'm definetly running boostless at this point. Now I can't talk to the ECU to see whats going on, and I can't shut off the engine as it won't restart. Now what? I drive home the rest of the way crawling up hills at 15-30 mph, hitting 60mph on downhills, and coasting tothe next hill. Royal pain in the ass.
Make it home, let it idle, grab my homework and go to a friends house. 3 miles away, still no boost.
Get there, shut it off, and try to restart. It restarts and this time with boost, went for a spin, and it was still not pullin low, but hitting hard up top. go back to his house, stay an hour, leave, and the car restarts once more, same boost condition, hiugh up top, maybe 30 seconds to 60, then it pulls like a freight train. REVs have to be above 3500 for ANY power.
This morning, start it up, and it dies immediately, try again and it runs fine. Go to town, still have no low boost, and high topend boost. I switch the valves back around, egr -> N75, and hit the road. I go get lunch, come back home, and shut it off. Start it and it runs, so I grab vagcom, and it talks to the ECU for the first time in 3 days.
Codes that it finds are
17571 - Fuel temp sensor (G81) Implausible sensor
17664 - Coolant Circulation Valve (N214) - Open Circuit
Now the car has been sitting for 5 hours, and it still won't start. Also can't talk to it with vagcom anymore.
No point in dealing with the dealer, as they won't know anything more than I do on these codes... I know its long, but any info any of you guys can shed on this is appreciated so MUCH. Thanks
William
William
