ken.fresno-tdi
Hi all, I've trying to figure out why I have a no start on my Eurovan ALH-TDI conversion. . I've been playing with TDIs for 15+ years so am quite familiar with them. I've also done two successful AHU-TDI -> Eurovan conversions so I am familiar with the basic conversion issues. I took the ALH engine out of my 2001 Jetta with 150K miles several years ago; took it apart down to the head, had head cleaned and surfaced; all new accessory parts; bought a rebuilt IP, and had engine wiring harness redone at Fast-Forward Automotive (https://shop.fastforward.ca/), including deleting immobilizer, mild-tune, and nozzle upgrade. Put it all together a few months ago but caught up in work, so now trying to start it for the first time. Triple checked static engine timing - IP and crank and cam are all timed as they should be using Metalnerd timing tools. Made sure plenty of fuel was coming out of IP using mity-vac pulling out air at fuel return outlet. Getting good squirts of fuel from each injector when cracking open injector nuts. I have 12V and good 109 relay (Fastforward wiring harness includes a relay with red light on top to indicate 12v). 12V measured at several of the 109 relay sensors including N75 valve and N109 valve. Tied anti-shudder flap open to make sure it was not cutting air to intake. Have initial 12v to fuel-shutoff solonoid, falling down soon after it starts (which is normal from what I understand). cranks very well with new battery. VCDS gives me three codes: 17970-Quantity Adjuster P1562 error - 'upper limit reached' - intermittent; 17569 Manifold Temp sensor (G72) P1161 "open or short to plus' (I'll check that but I don't think anything serious for starting); and 16491 manifold pressure sensor P0107 signal too low (could be because exhaust is not yet hooked up). One concern is the first error code re quantity adjuster: Would that prevent it starting? I don't know why I would get that code on a newly rebuilt IP... ? The engine sat for three years because of work busyness but I had the engine all together and sitting on a engine stand in my garage prior to putting it in the van this winter. The ALH engine is tilted forward about 20-30 degrees in the Eurovan instead of backwards about 15 degrees in the Jetta; I assume that is not an issue since the Vanagon TDI conversion sits very different from stock.
What else have I forgotten to check??
