rotaecho
- Joined
- May 29, 2015
- Location
- Phoenix
- TDI
- mTDI AHU in an 82 Vanagon Diesel & 86' 1.6na Golf (destined TDI) & 00' Golf 4D
So, I am building up an AHU engine to be a bit stronger. I purchased some EuroSpec connecting rods from Cascade German awhile back, since it was listed as 1z, AHU, ALH, RM, and BEW and were a good price.
Well, after getting the oversized pistons installed and putting in the intermediate shaft getting closer to finishing the build, I noticed I couldn't rotate the crank past 180deg.
Upon inspection it appears to be hitting the intermediate shaft. I believe at the fat end towards the front of the engine. Everything rotates fine when I remove the intermediate shaft.
What have people done in this situation? If I machine the shaft to the width of the center or end diameter will this cause structural damage to the intermediate shaft? Any advice here is appreciate.
And "Well you should have bought these XYZ rods instead!" would be fine, hindsight, but list them anyways, as I will likely be building another AHU again.
But for "now" what would be my best course of action without throwing the rods away?
