I assume we need the 12V? Do you have to get one with an internal coolant pump and fuel pump? Does the interior vent fan switch on too? Does the unit use the car's in tank fuel pump or just it's own?
Yes the 12 v version is required. I am using the model with the internal fuel/coolant pump. I also have an extra external fuel pump as well cause it came with the heater. The internal fuel pump can be used as long as it is within the required distance from the fuel tank. VW did a very clever thing by adding an auxilliary fuel port on top of the sending unit which can be tapped into to draw fuel from. The metal pick up tube that comes with the kit is not even required on these cars.
I found my Espar on kijiji. I think the fan can be wired to turn on after a certain temp is reached but not really necessary in my opinion. It will just be a bigger draw on your battery.
The heater can be left on while you drive but I wouldnt personally leave it on for 12 hours without the car running. These heaters are more than enough for these cars they use them on Dodge rams, Ford powerstrokes ect.
Link for some stats from Espar website on the Hydronic 5 (D5):
http://www.espar.com/html/products/hydronic5.html
Espar offers 2 versions for the D5, one like mine with internal fuel/coolant pump and another version with a external fuel and coolant pump. Both can be used I am pretty sure.
You have 3 options to operate your heater. Cheapest is the basic push pull switch, most expensive is the 7 day timer.
1. Push pull switch
2. Mini timer
3. 7 day timer
I like the 7 day timer because it also gives you onboard diagnostics ie. fault codes which are handy.
Another nice thing is if you want to remote start the heater you can. As for the 7 day timer all that is required to start the heater remotely is a negative pulse to pin #7 on the timer.
Bushed, sounds good let me know.
