Out and about in my 2003 tdi today.... previously running close to perfect and I went over some rather vicious washboard. Would have slowed down more than I did if I'd recognised how bad it was. Regardless as I try to accelerate at the end of the wash board, no way. Wouldn't rev passed about 1200 rpm, sounded and felt like a 4 cyl gas motor running on only one cylinder. No excessive smoke, no apparent oil leaks. Managed to struggle home at nothing better than 20mph in second gear....... wouldn't pull third. Had to pull in at a mall lot when the lights were against me at while idling there , full throttle managed to rev passed 2000rpm with very large quantities of black smoke. but quickly cleared and again 1200-1400 was the best we could do.
Thoughts of damaged turbo or hose that had popped off crossed my mind as well as possible skipped tooth of timing belt. However once home , no oil leaks confirmed , oil level is normal and all hoses apparently OK.
And yes the vehicle is fitted with a aluminium skid pan so its unlikely that anything was kicked up towards the belts.
Hooked to VCDS to pull only one code.. 17656, P1248-35-10, Start of Ignition Timing Regulation , Control Deviation Intermittent.
Best guesses as to what has happened please. I'm not bad mechanically but I don't trust myself to play with the fuel pump nor to do timing belt work. Maybe that will have to change but I need pointing in the right direction.
And if anyone in the Calgary area wants to earn a few $$$ , Ill gladly pay for competant help.
