Pitchar
2011 Jetta tdi help
Hi I’m looking at buying a Jetta. I am a diesel mechanic and was looking at this one Jetta that isent running. It has 2 dtc. One is p1007 torque difference cyl. 4 and a p0087 low fuel rail pressure. I was wondering if this combination of codes points a specific problem such as a bad injector on...
forums.tdiclub.com
Driving to work yesterday morning, temps in the mid 30's, car started and ran fine. After a couple miles it loses power and starts to stumble. The coil dash light flashes and within 50' the engine shuts off and I was able to coast without power steering or power brakes to a safe parking area. It will crank but not turn over. I plug in my Harbor Freight scanner and code P0087 comes up, "fuel rail/system pressure too low"
I searched the site and found the above thread. Is this as simple as replacing the fuel temperature sensor?
Pitchar
